I successfully use the BFC 2000 midi controller with USINE, but I can't find the way to remote it. I can control USINE, but USINE doesn't seem to be able to control the BFC. The faders don't move when they should.
Did I miss something ?
Thanks !
DC
how to remote the BFC-2000
Hello Daviche,
In the setup, midi out, you had to choose the remote, the BFC2000
And on each midi learn, you had to choose to send remote (ctrl-clic on the fader, dialog box)
Hope it works better
if you press 'U' in the left upper corner, the bcf will be updated (if the params are set as daviche said)
for further refinement: there might occur cases when ur bcf wont be updated automatically. for example if you deactivate a track or if you change the preset of a vst. if u need help here, just ask.
