If you look carefully you will see important details like the possibility to mix background images:
In this example a Wave Display is mixed to a Data Lines modules and a Filter is mixed with a XY pad to adjust the filter settings.
It is currently 14 Oct 2026, 23:41
Unread post by senso » 14 Nov 2008, 22:37
Unread post by nay-seven » 15 Nov 2008, 09:12
Unread post by Vincent » 31 Dec 2008, 15:22
Return to “General discussion”
