Hi Olivier
When i select a MIDI wire
there is two type of data
MIDI data for exemple [xxxx:o ON 35 120 c1]
and some time between MIDI data there is [yyyy:[0]]
what are this type of data ? (just to informe, this are not filtered by the MIDI filter modile)
are they a problem if you transmit it to a VSTi for exemple ?
I'm trying debuging a patch...
Charles
what is a [0] data ?
I'm not quite sure, but I think it's a way of showing that the MIDI array is empty, ie length=0. I'm pretty certain that it isn't anything to worry about.
Users browsing this forum: No registered users and 825 guests
