I love the pace of Usine development (for live use, I'll probably upgrade about twice a year, but it's good to experiment with new versions in the safety of home) but I'm getting a bit tired of entering my paths, and preferences every time I install a new version.
Is there a way to import settings? Some file that I can copy from the last version of usine? I thought it might be UsineData.txt, but that didn't work.
Thanks!
-eric
getting preferences from old versions
you could import these files in your new version :
VstScan.ini
Default-settings.ini
Default-Remote.remote
Default-Master.master
cheeers
VstScan.ini
cheeers
Or of course use your own file names, but then you have to select them.
Clearscreen
In the global setup menu theres a file menu where you can save your setup. you can also do this with the midi and key learns as well so you have backups.
thanks so much!!
Users browsing this forum: No registered users and 291 guests
