About interactivity
groolot
- New member
- senso
I'm currently working on this subject. I try to keep Usine as simple as possible. I hope it will arrive soon.
groolot
- New member
What do you think about adding a more efficient way to disconnect a link between modules.
Because, if you want to disconnect a modules you have to ... do what ? Delete the module and then re-create it with new links ?
Gr?gory DAVID 'aka' groolot
http://www.groolot.net/
- senso
The actual way is simple but sometime heavy...
The best thing should be to select one (or more links with the shift key for example) and move it.
I'll try to add this functionality soon.
