Reductions Negociated on the purchase of a tablet PC
Unread post by senso » 23 Oct 2008, 21:05
I have negotiated a reduction on the Clevo tablet pc for Usine users.
You can save directly 6%.
For a good audio configuration you can save between 80€ and 100€
A Core 2 duo 9300 4GoRAM, fastest 160Gb 7200 hard drive will cost around 1100€, included the reduction.
For that just enter SENSO in the promotional code field. (Sorry, it's a French site)
http://pcw.fr/index.html?lmd=39731.576169
Of course I don't make any money or any benefice on the transactions, it's just a service offers to Usiners!
Unread post by grego mondo » 23 Oct 2008, 22:55
great !! thanks
Unread post by bsork » 23 Oct 2008, 23:07
...but the NOK/EUR ratio is the worst ever... :( From my point of view, at least.
le-blob
Unread post by le-blob » 10 Nov 2008, 14:04
Hi, I'd like to know if the 6% discount on a clevo PC is still available ??
Is it isolated enough to be plugged on directly to a sound system ?
Thanks for your answer
Unread post by senso » 10 Nov 2008, 14:37
yes just enter 'SENSO' in the promotional code
do you mean without an external sound card (only the built in)?
le-blob
Unread post by le-blob » 10 Nov 2008, 15:08
with a multiface RME + cardbus and pc express adapter
Unread post by senso » 10 Nov 2008, 18:05
no problem!!
amiga909
Unread post by amiga909 » 10 Nov 2008, 18:35
le-blob wrote:??
did you mean with isolation magnetic shielding?
cheap laptops often have the problem that their housing isnt well shielded. the AC interferes with the soundcard and what u hear is grounding noise (sometimes modulated by HD noises). had/have this problem with my dell inspiron 8100.
there is a workaround for this (spend 20$ in a specialized electronic shop for a 'mantelfilter' (english?)).
le-blob
Unread post by le-blob » 10 Nov 2008, 21:15
Thanks for the tip. But what's the French for Mantelfilter ??? Did you ever have this shielding problem with your clevo ?
Unread post by senso » 11 Nov 2008, 09:35
Absolutely no problem.
sometime I use a ground isolator (cost 0.50€) not especially on the clevo.
le-blob
Unread post by le-blob » 11 Nov 2008, 11:45
thanx a lot, merci bcp
fractal
Unread post by fractal » 04 Jan 2009, 19:16
Hi guys !
I'm a new "futur" user of Usine pro.
I'm a fan of Reaktor and i think Usine can be wonderful for me (sorry for my crappy english , i'm french and the school is so far now... :) )
I first lookin' for a Lemur (i have a monome 128 and Audiocubes from Percussa, i'm always lookin for a new way to make music.)
But it's a little bit overpriced for me...
And i discover Usine! (i think it's a little bit under exposed, make more videos, with each add-on for example... :) )
First question (but not the last!) :
What good tablet Pc for Usine? the minimal spec/performance (i want use it like a Lemur for Live and make my own control)?
i'm lookin for a Used Dell XT Tablet (650 euros) but 1,2 ghz scare me a little...
Have you some suggestion? my budget(is the good word?) is around 600-700 euros (no problem for used gear/Tablet)
Hope you help me :)
See ya !
Ps here my myspace if you want see some videos/tracks : http://www.myspace.com/fractaldeath
Unread post by senso » 05 Jan 2009, 20:07
this one is perfect!
for 1000€ you can have a very powerful config.
fractal
Unread post by fractal » 12 Jan 2009, 13:56
Merci Olivier !
i continue in english :)
I'm going to buy the Hp Tx2z more powerful and multitouch screen(well Bi touch...)
And i'm goin to try Windows 7 beta on it.
Usine can work with a multi touch environnement?
If you want when i have all the material, i can beta test your Multi touch Usine :)
See ya !
Unread post by senso » 12 Jan 2009, 15:05
usine woks better on windows7 than xp or (of course) vista.
it's a good news!
but for the multitouch you have to test.
let me know.
I plan to work on the multitouch next month.
Unread post by nay-seven » 12 Jan 2009, 18:36
whaou ! good news...!
