Sequencer: moving items
maxdis
Unread post by maxdis » 19 Oct 2008, 16:52
Hi
I have some audio files in the sequencer, and I want to move them alltogether...so I choose "Select all" and drag and drop them with the mouse, but now I'm finding the items are not anymore in sync each other...I'm missing something?
thanks
Unread post by senso » 19 Oct 2008, 18:58
Actually when you move several objects all of them are snapped according the 'snap' option : none, grid, object.
So they can lose their relatives positions except if you chose the snap=none
It's tricky and I'll change it in the next version.
the automatic snap will be disabled when several object are selected.
Unread post by bsork » 19 Oct 2008, 22:19
More programming I'm afraid, but...: What if you "anchor" the chosen snap option with the first patch in the selection, and retain their relative positions to that?
Unread post by senso » 20 Oct 2008, 09:01
yes it the best solution.
Users browsing this forum: No registered users and 339 guests
