Touchscreens Lemur and Osc
djthopa
Unread post by djthopa » 09 Oct 2008, 12:33
Hi all,
Thanks for the program! Its´great; but i´ve runned into some questions:
a) Can Usine host vst´s while in vst mode
b) In Standalone mode, is it possible to load vsts (like reaktor) and control reaktor parameters with a touch screen? Meaning not having to configure every parameter, just touching it trough the touchscreen.
C) I own a Lemur and I was wondering if it can be used as a touchscreen with Usine, and how are you guys using it with Usine. Do you have to create new objcets on The jazzeditor and Osc target these, or is it done inside Usine?
Thanks for your time
Thopa
Unread post by bsork » 09 Oct 2008, 12:49
a) Yes.
b) The touch screen only mimicks the mouse anyway, so you can use it directly on any VST's GUI. I don't have any touch screen myself, but I suspect there might be some problems using fingers to control small GUI objects, though...
c) Someone else has to answer this.
Unread post by nay-seven » 09 Oct 2008, 12:49
hello
a ) yes you can
b) i think the best way is to create your own controls ( knob , fader and so ) to control only the reaktor's parametrers you need , that's more the Usine way / feel...
c) can't answer to this one , don't have one...
Unread post by nay-seven » 09 Oct 2008, 12:52
ha ha , you win with 34 seconds bsork.....;-)
djthopa
Unread post by djthopa » 09 Oct 2008, 12:59
thanks, Ill try to find out aobut the copmpatibily with the Lemur
Unread post by senso » 09 Oct 2008, 13:21
c) in the addons/other section you'll find a set of ready made patches to communicate with a lemur in osc.
But the lemur is not a screen!
djthopa
Unread post by djthopa » 09 Oct 2008, 13:34
Thanks for your reply,
I´ll check it out
Users browsing this forum: No registered users and 301 guests
