Lfo Sync
A simple patch with a synchronised Lfo.
You can use it to connect it to the pitch inlet of a sampler or a pitch shifter
to create a vibrato effect for exemple.
In order to save your settings within the patch, you've got to press the manual switch,
once you're ok with you tempo.
I've discovered after making this patch, that there was yet one in Usine...but that was not a reason to not sharing it.
In audio effect add-ons
It is currently 14 Oct 2026, 13:44
Lfo Sync
Return to “Add-ons discussion”
Jump to
- News
- ↳ News
- English Forums
- ↳ General discussion
- ↳ How to send a Bug Report
- ↳ Suggestions & improvements
- ↳ Patching questions
- ↳ Add-ons discussion
- ↳ Additional Packs
- ↳ Module development SDK
- ↳ Artistic Zone
- ↳ Registration procedure
- ↳ Manuals & Wiki
- Forums Français
- ↳ Discussion générale
- Home Board index
- All times are UTC+02:00
- Delete cookies
- Privacy
- Terms
- Contact us
Powered by phpBB® Forum Software © phpBB Limited
