Usine vsti - i/o
komuso
Unread post by komuso » 06 Oct 2008, 05:04
Hi!
Many thanks for help on my previous midi questions, using Usine in standalone mode.
I got the setup working with correct audio/midi io.
Now I'm using Usine as a vsti in Reaper.
The problem is I don't get see any of the audio or midi devices that I see in standalone mode.
Does the vsti operate differently?
I was expecting the setup to be similar, with the ability to select the I/O's to route midi, but the setup dialog does not list all the devices that are listed in standalone mode.
How are you supposed to select midi devices in vsti mode then?
Many thanks,
kt
Unread post by nay-seven » 06 Oct 2008, 08:12
hello
consider Usine vsti/vst as any other vsti/vst , just insert them in your track , and select your midi in in the track of Reaper....( right clic on the "in" button of the track )
now , you can route this midi /audio signal as you want inside the Usine vst
Users browsing this forum: No registered users and 909 guests
