midi fader: custom note range?
Androidmonk
Unread post by Androidmonk » 03 Oct 2008, 01:22
Is there a way to change the note range of the midi fader?
I'm working on a patch that lets the user select a custom scale, and I'd like to have the sliders set to a 3 or 4 octave range.
ethnix73
Unread post by ethnix73 » 03 Oct 2008, 10:13
If you are you talking about the FaderNote module, you can change value in the control panel or using the data/data manipulation/change scale patch...
Seb.Dub
Unread post by nay-seven » 03 Oct 2008, 12:39
you also have a script named " Midi Transpose" in the script dir
and also a Midi Dispatcher for the choice....?
Androidmonk
Unread post by Androidmonk » 04 Oct 2008, 01:54
Thanks! I'll check it out.
