Preset manager
ethnix73
Unread post by ethnix73 » 14 Sep 2008, 13:00
Am i wrong or does the preset manager module does not store values for subpatch?
Seb.Dub
ethnix73
Unread post by ethnix73 » 18 Sep 2008, 00:43
Edit:
Preset manager doesn't seem to store directly values for sub-sub patch.....but some workaround might be possible i suppose.
Seb.Dub
Unread post by senso » 18 Sep 2008, 14:26
you're right.
It's probably time to change the Preset behavior to feet to new possibilities of Usine.
Vincent
Unread post by Vincent » 18 Sep 2008, 23:57
Hi ethnix73,
The PM stores the values of the controls in the same patch.
For sub-patches, I would suggest 2 solutions:
- connect controls to the inlets of the sub-patch - and their values will be stored in the PM
- add a PM in the sub-patch and make it work in parallel with (or chain it fully to) the main PM ('num', 'store', 'recall', and so on). I must say that I never tryied this one!...
I hope it helps.
vincent michel
composer & novelist
ethnix73
Unread post by ethnix73 » 19 Sep 2008, 01:07
i've just done what you suggest in your second solution. We had same idea.It works fine...
Seb.Dub
Users browsing this forum: No registered users and 268 guests
