Opening USINE and a wave editor in the mean time, is it work?
cybercharles
Unread post by cybercharles » 30 Jul 2009, 12:05
Hi
If I want to edit an audio sample while USINE is open, WAVELAB return me a reading error message because my audio driver is still used (…in fact by USINE).
My sound card is an RME Fireface 400.
Is it possible or not opening both USINE with a second sound software? And How?
Regards
charles
t
Unread post by nay-seven » 30 Jul 2009, 12:48
try asio4all for your wave editor....;-) ,
ethnix73
Unread post by ethnix73 » 30 Jul 2009, 13:14
RME driver might be multi-client. Enable different audio outputs within Usine and Wavelab...Or try the solution of nay-seven
Seb.Dub
Unread post by bsork » 30 Jul 2009, 13:38
Would it be hard to implement to something like the "Release ASIO driver in background" option in Cubase? Obviously not something to have on in a live setting... ;)
cybercharles
Unread post by cybercharles » 30 Jul 2009, 15:19
following ethnix advice I find a solution using RME matrix. In Wavelab i chose different audio output than USINE and with the matrix i drive the signal in my main monitor output (same as usine).
thanks guys
charles
t
Users browsing this forum: No registered users and 437 guests
