bezier curves
Unread post by 23fx23 » 14 Jul 2009, 18:10
sorry if i already asked,don't remember on wich forum i already asked :) ,couldn't find in database so maybe not yet here...
Might sound stupid but i have always dream about correcting my wavforms via bezier curves,hand drawing that is comon is not clean enough. other approach with sins like absynth are limited too. In drawing apps there is an extensive use of bezier curves,
sadly not in audio soft, would be so more handy for ie automations,any log curve would be made/readjusted with adusting one bezier point.only.
im after strong phasing ie kick n bass to make some "combos" would need to slight ajust phases. or in any layering sounds would be far more easy, and wavform creation would be creative i guess..even kicks creation
have anyone ever seen a bezier app to draw/correct wavforms or generate curve/ramps? and more generally any audio soft using true bezier? or any way to import some..
amiga909
Unread post by amiga909 » 14 Jul 2009, 19:43
control data only: 2 sequencers, spline curves for parameter automation..i know its not what u wanted, but i've already looked up the links ;)
- podium
http://www.zynewave.com/about.html
- temper
http://www.angryredplanet.com/temper/
Unread post by 23fx23 » 14 Jul 2009, 20:46
thanks amiga, yup not exactly but im happy to know it exists. podium automation gestion is really impressive, exactly the way I was thinking about with that auto reduce points feature, wondered if was possible, seems yes (by the way usine feature request ??) . i wonder maybe I could output wavcurves if i feed it with a straight offseted line sound, gonna try.
thanks again
Unread post by senso » 15 Jul 2009, 09:21
the smoother module can do a good job in most situations. Also you can adjust the smooth quantity, which is harder with bezier curves.
Users browsing this forum: No registered users and 554 guests
