Just picking your brains again guys....
What do you feel the main differences between max msp and usine are?
max vs usine
my 2 cents:
max msp is a general multimedia programming application, with much more low level programming facilities. usine on the other hand is a music application that has its focus on the creation of live setups. there is no non-programmer approach to max, whereas usine serves both programmers and musicians.
i guess u could do everything in max what u can do in usine. but it would take much more time.
never done something with max msp thu.
This is the impression I was getting. I really want just to create a suitable environment for playing and then play music rather than continuously programming basic building blocks.
Thanks for your input though
blugaruda
blugaruda
Max is a brilliant soft. for me the main differences are:
1) Usine has more macroscopic modules, and you can patch faster
2) Max has an object approach: you put object on a patch and you exchange informations by 'messages'. (typically in the 80's style of programming ?). At the contrary Usine has a flux approach like a guitar player and his 'pedals' connected by cables. It's a newer approach.
the major advantages in my eyes
- conductor (snapshots for master, patches and subpatches!)
- easy midi learn everywhere for everything
- nice interface objects for quick parameter automation
- integrated GUI design
- sequencer
.. some of the points are surely possible with max too. still, it may also show advantages over other music programming softs like bidule, PD, audiomulch, synthedit, synthmaker..
as i understand it 'flux-based' relates to the behavior of a constantly running analog oscillator, while 'message-based' is something like a digitial midi keyboard. in Usine mostly everything (besides midi) behaves like oscillators - control data communication too.
this surely reminds of how real hardware works, as senso says.
and in Usine a lot of stuff is faster to do. on the other hand u got to use a lot of event control modules (hasChanged etc.) when u want a, say, 'message-based' behavior. i'd conclude 'flux-based' is just another attenuation?however, i like it this way - its more 'organic'
- sequencer
as said i am not a max user, but i wouldnt agree 'message-based' is not as a good as 'flux-based'.senso wrote:2) Max has an object approach: you put object on a patch and you exchange informations by 'messages'. (typically in the 80's style of programming ?). At the contrary Usine has a flux approach like a guitar player and his 'pedals' connected by cables. It's a newer approach.
cybercharles
+1 for all comments
Up to me, the main and first advantage for USINE VS MAX is that: after programming your patch is represented in a user friendly environment !
for synthesis (FM, additvie...) MAX is more extended.
we can use this maxim:
"...whith max you learn programming, whith usine you play music..."
t
Users browsing this forum: No registered users and 489 guests
