manual french translation
- senso
yes yes, yes!!
If it can help,
I have uploaded separated images http://www.sensomusic.com/wiki/doku.php?id=manual:index
I can upload images in the wiki folder so they can be accessible directly in the upload form. so tell me if you're interested.
I have also on small remark:
I'm not sure you're obliged to keep the chapter index number :
====== 2.Vue d'ensemble d'Usine ======
can be replaced by
====== Vue d'ensemble d'Usine ======
I think it's better if we want to change the order easilly?
If it can help,
can be replaced by
ethnix73
ok olivier for the chapters...
"I can upload images in the wiki folder so they can be accessible directly in the upload form".
yes, i believe it' a better way if images come from you. We will have the same set of images for everyone. Once they are uploaded they can be usefull for the how to, or others translations...
Should i translate annotations in the images or not? Don't know if it's a better idea to keep them in english and explain them in french...
I'm wondering also how to translate correctly a few terms like timeline, remote...
Seb.Dub
- nay-seven
Fantastic job guys !
it's very strange to see the manual in French now ..so long we see it in English...!!
hope i'll find time next days to help you...
- senso
I think that we are not obliged to translate images annotations?
We'll do that slowly later?
PS: Images are already uploaded
ethnix73
yes, it's better not to translate anotations...Usine is still in english, and i believe it's more helpful with annotations in english.
@ nay-seven: there might be some errors for sure, correct them when you see them if you want...Translating is not as long as i thought.
Seb.Dub
- nay-seven
yes it is..
- senso
I've change the organization of pages.
After several tests, the manual in one single page will be too big for the wiki engine so I think that it's better to use separate files.
I'll spit your french version too if you don't mind ?
La Tenaille
It could be the title of a novelsenso wrote:I'll spit your french
La Tenaille
[french]
Salut, je me permets le français vu que ce topic s'adresse uniquement aux francophones.
Tout d'abord bravo ethnix73 ! C'est un boulot ingrat.
J'ai fait une relecture du 1er chapitre "vue d'ensemble", et changé quelques tournures de phrases, fotes d'otograf etc...
Si ça vous convient, je peux continuer à mes heures perdues. C'est le genre de coup de pouce à ma portée.
PS : vous écririez "patchs" ou "patches" en français ?
[/french]
[/french]
- senso
[french]
et pi Ouais on parle français sur ce topic.
En tout cas bravo à ethnix pour la traduction, super boulot.
En français on dit plutôt 'les patchs' mais bon je ne suis pas Bernard Pivot....
@la tenaille: tout les coups de pouce sont important!
n'hésitons pas à nous modifier les uns les autres, c'est le principe même du wiki.
[/french]
[/french]
- nay-seven
[french]
[/french]
ha non...pas de ça ici...senso wrote:n'hésitons pas à nous modifier les uns les autres
[/french]
La Tenaille
Ok, j'ai un peu avancé
Il y a des choix pas faciles à faire, tu dois t'en voir !
Je suis content de passer après toi
- nay-seven
t'est un chef !
penses à reposer les yeux de temps en temps..
La Tenaille
Pour info, les images 31 et 36 ne s'affichent pas chez moi (section patch grid du manuel). Je suis sous firefox/linux, ça vient peut-être de là ?
- nay-seven
non, elle semble absente du media files manager aussi , ainsi que la 34...besoin de les re-uploader je pense...
- senso
scroller.
pas évident, et le verbe 'to scroll' encoer moins.
laissons 'scroller'?
c'est peut être mieux même si on se fait flingué par l'Académie Française...
sinon, il y a ascenceur (si vertical), 'barre de déplacement rapide', un peu lourd?
C'est un peu comme 'Sampler'. Ce mot est plus explicite pour les musiciens que 'échantillonneur'?
je regarde les images 31,3436
PS: ethnix le Wiki-Luke?
martignasse
défiler ??ethnix73 wrote:Comment traduire correctement scroller?
mais ca dépend du contexte
martignasse
littéralement en langage technique : chaine de caractèresethnix73 wrote:string?
a+
- senso
à priori non car c'est déjà le terme employé pour la barre d'Interface builder en mode touch screen.moody33 wrote:Scroller? "Barre de navigation "
ethnix73
C'est bien ce que j'avais commencé à utiliser comme terme, mais c'est un peu long et lourd je trouveMartignasse wrote:littéralement en langage technique : chaine de caractères
P.S: le manuel sera en ligne ce WE, sauf le chapitre sur les scripts car je suis incapable de la traduire...
Seb.Dub
- nay-seven
quel bourreau de travail....!!!!P.S: le manuel sera en ligne ce WE...
tu es de la famille d'olivier toi nan...?
- nay-seven
dans le sens "claquement de doigt"...?
martignasse
Snapping mode : système d'aimantation... en tout cas c'est le principe, je vois pas de terme plus 'leger'.ethnix73 wrote:lol,
Comment traduire correctement snaping?
a+
- senso
au fait j'ai commencé à relire, dans le but de dégager qq vieilleries qui dates de 1934 et je dois dire que je trouve la traduction EXCELLENTE!!!!
merci à tous pour votre participation.
- senso
j'avais un pb pour imprimer les images du coup j'ai transformé les .png en .jpg.
J'espère que je n'ai pas fais trop d'erreurs....
ethnix73
Voila, la traduction est en ligne...Reste encore:
1) la traduction du chapitre sur les scripts que je ne peux faire (vu que je comprends rien au scripts),
2) et toute la traduction de la description des modules. J'ai commencé, mais je pense faire ceci plus tranquillement. Je mettrai plus de temps que pour les autres chapitres du manuel...
Seb.Dub
ethnix73
J'ai commencé a finir la traduction de manuel. je n'avais pas traduit toute la partie référençant et expliquant les fonctions des modules...Il y a eu quelques sujets sur audiofanzine. Donc, jeme suis dit "allez, je finis".
"Modules audio" traduit....si quelqu'un veut corriger.
Seb.Dub
- senso
whaooo!!
top
top
- nay-seven
yep , bien cool la traduction des modules , ça va en aider plus d'un !!!
dont moi d'ailleurs...
ethnix73
Modules traduits:
Audio
Data
@Nay-seven: enfin, je pense qu'il y a de la correction à faire quand même. Certaines traductions sont un peu difficiles. Autant je comprends bien en anglais, autant j'ai parfois du mal à le transposer en français sans faire des phrases à rallonge.
Audio
Data
Seb.Dub
- senso
"y'a que ceux qui font rien qui se trompent jamais" comme dirait ma grand mère...
on va tous s'y mettre!
- nay-seven
oui , bien sur , mais tu es quand même en train de te taper tout le sale boulot...
alors merci à toi..
après oui , Bar pourrait être traduit par Mesure , mais bon...
en tout cas j'aime bien tes " nuage de grains " pour le granulaire...
alors merci à toi..
ok, jarrete un peu, faut qje patch un peu
, j'ai fais une première passe sur les derniers, a checker updater un peu:
Controle des Évènements
Math
Chaines & Texte
Réseau & Open Sound Control
Video
effectivement string/ chaine de caractaire c un peu dur de choisir. le français c vraiment souvent plus long que l'angais hehe.
mais bon "envoyer un string par le reseau?"
Math
Chaines & Texte
Video
- senso
en tout cas bravo les gars, super boulot!
- nay-seven
cool !
Je commence une relecture , j'ai un correcteur dans Firefox , donc je repère facilement les histoire d'accent et les mots collés...
- nay-seven
en passant l'aide pour le module Midi Player/Recorder est toujours la , alors que le module lui ..non...depuis un moment..
on efface..?
sinon, pour "sharpness" je propose " finesse"..?
relecture faite pour :
audio
data
midi
on efface..?
audio
data
midi
martignasse
he les gars,
chapeau bas, vous assurez un max
ethnix73
Interface control traduit. Par contre, je n'ai pas traduit le module Trace Value. Je ne le connais, et ne m'en suis jamais servi...il faudrait donc que je vérifie son utilisation avant de traduire.
Je pense qu'il faudrait vérifier les liens HTML. Je les ai modifiés dans les dernières traductions uniquement (à partir d'interface design). Apparemment, dans le manuel c'est fait...
Une petite question:
1) Peut on modifier le panneau Main Wiki pages, afin que les liens pointent directement sur les traductions éffectués; plutot que de devoir cliquer sur "fr" à chaque fois?
Maintenant, il restera à traduire les légendes des images...
Souvent, j'ai mis lenom en anglais entre parenthèse. En effet, si Usine reste en anglais, je pense qu'il n'y a pas d'intérêt à tout traduire.
Seb.Dub
yes finito les modules, reste un recheck, moi aussi vu que dans le soft c en anglais, je trouve mieux de laisser le terme anglais et tenter une trad entre parenthèse) un gate ça me parle plus que....mmm un gate en français?
il semble aussi qu'il y ai des modules qui ont disparus, remplacé depuis (pich tracker), ya aussi des nouveaux (roll array),
que je n'ai pas implementé, peut etre d'abord on recheck se qui à été fait et on fait un point.
bien joué etnix, g vu le temps que ça prenais et t'a abattu une vraiment grosse masse de taf à toi tout seul, mais tu doit etre un expert maintenant
martignasse: chelou g un mess qu'a disparu, jte remerciais toi et senso pour cette 4.22 excellente..
edit oops jplane il a pas été supp..
- nay-seven
cool , je me remets à la relecture...
- nay-seven
idée à propos de ta traduction des expressions " logarithmique" et "exponentiel" ( ex : fader )
"La valeur numérique grandit doucement sur le coté gauche, et de plus en plus vite vers le coté droit."
je pensais que l'on pourrai remplacer " coté gauche " par "début de la courbe " et fin de la courbe , ,comme ça on reste dans l'idée de temps...?..
quitte à mettre un petit jpg...?
grabbs
- New member
Je suis allé voir la def relative à "to scroll" : je pense que c'est "faire défiler"
scroll noun rouleau m. scroll down:
~ down (person) faire défiler de haut en bas;
~ down [sth] faire défiler [qch] de haut en bas (document).
scroll up:
~ up (person) faire défiler de bas en haut;
~ up [sth] faire défiler [qch] de bas en haut (document).
'TO SCROLL' found in these entries:
French:
défiler
scroll up:
French:
défiler
- nay-seven
@grabbs , ici il s'agit de traduire le mot "scroller , pas le verbe scroller" ça donnerait defileur...?? dsl..
sinon
relecture faite jusqu'à "Modules de contrôle de l'interface (Interface control)"
je vais manger un morceau..
sinon, j'ai mis de petits jpg pour les log et exp ( en doutant de moi car je trouve des résultats inverses sur le web..donc à vérifier senso...
@ethnix sinon, j'ai traduit le trace value :
en gros ce module envoie n'importe quelles suite de données dans la console d'usine
exemple , tu relie un modules line , tu dessine une courbe et tu fait play , ensuite tu ouvre la console et cela te permets de faire un copier coller de ces valeurs..
dis moi si c'est pas clair..
sinon
- nay-seven
encore une question :
version anglaise et fancaise pour le module array:
La valeur de réinitialisation est appliquée quand le bouton reset est pressé ou quand l'utilisateur effectue un [shift+click] sur le panneau.
ce n'est pas plutot (ctrl) click pour le reset...?
- nay-seven
encore le chieur : il faudrai un pro de la mise en page pour les modules logic ( anglais et français )
les explications 0 1 sont sur une seule ligne ( ou alors ça vient de chez moi..? ) et du coup ça ne veut rien dire...
regarder dans le browser d'usine et faite " show info " vous aurez la bonne disposition..
ou alors on fait un screenshot...
- nay-seven
oui , c'est mieux , mais pas sur qu'un débutant comprenne la logique ( c'est le cas de le dire ..
) du truc
peut être rajouter ( dans le A and B par exemple ) :
lire verticalement , exemple ici : si A=1 et B = 1 alors sortie = 1
- nay-seven
j'ai triché et rajouté une colonne...tu me diras si ça te va...
gercha1
où est ce qu'on peut télécharger ce manuel en français ?
bravo et merci pour ce beau et long travail
gérald
gérald
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
- nay-seven
wiki / user's guide / petit carré bleu " fr " / Ouvrir la version imprimable
pareil pour le "modules reference "....
ne pas se fier à l'apparence , le document sera bien imprimé sur fond Blanc...
- nay-seven
cool !
merci !
merci !
