UsineMain
ethnix73
Unread post by ethnix73 » 15 Jun 2009, 00:24
A little question for mr Senso:
On most updates, can we just replace the UsineMain.exe instead of the entire package?
Seb.Dub
Unread post by grego mondo » 15 Jun 2009, 00:56
I was wondering it too ...
Mothballs
Unread post by Mothballs » 15 Jun 2009, 04:22
Would make life a little easier.
Unread post by senso » 15 Jun 2009, 09:07
it's true for most small release.
but sometime it's not because the library or the modules list can change.
With leVraibernardo, the web master, we plan to create a simplified Update procedure over Internet.
Also another alternative should be to save the setup from the old version and reload-it in the new one.
ethnix73
Unread post by ethnix73 » 15 Jun 2009, 12:01
@yes, that's what i'm doing concerning the setup.
Seb.Dub
Unread post by grego mondo » 15 Jun 2009, 17:11
Yes for setup and remote ...
nofish
Unread post by nofish » 15 Jun 2009, 23:03
How about an option for storing the personal settings/preferences alternatively in Documents and settings/ application data like other programs do, so they wouldn't get overwriten when installing a new version.
Just an idea...
ethnix73
Unread post by ethnix73 » 15 Jun 2009, 23:31
@no fish: that's what you can do by saving your setup! or i have misunderstood you.
Seb.Dub
nelson
Unread post by nelson » 15 Jun 2009, 23:39
nooo.. its good idea that usine has all files in one place and no instaler. moving setup files to documents and settings folder would make it less portable.
maybe there should be small update pack only with updated files and without setup files etc..
Users browsing this forum: No registered users and 450 guests
