UsineMain
I was wondering it too ...
it's true for most small release.
but sometime it's not because the library or the modules list can change.
With leVraibernardo, the web master, we plan to create a simplified Update procedure over Internet.
Also another alternative should be to save the setup from the old version and reload-it in the new one.
@yes, that's what i'm doing concerning the setup.
Seb.Dub
Yes for setup and remote ...
How about an option for storing the personal settings/preferences alternatively in Documents and settings/ application data like other programs do, so they wouldn't get overwriten when installing a new version.
Just an idea...
Just an idea...
@no fish: that's what you can do by saving your setup! or i have misunderstood you.
Seb.Dub
nooo.. its good idea that usine has all files in one place and no instaler. moving setup files to documents and settings folder would make it less portable.
maybe there should be small update pack only with updated files and without setup files etc..
Users browsing this forum: No registered users and 479 guests
