Gizzeta wrote:hi,
need help again...
I create a module that fill a buffer with a waveform stored in an external file and read it as a loop (oscillator).
it works nice, but when I add a second instance of the same module (even if not connected) it affect the output of the first module (it sounds like a frequency modulation). WHY???
Normally all the variables and pointers are internals to every instance of the module(private)...or not?
Thanks for your help
Problems when using two instance of a module
martignasse
Copy of the original question :
martignasse
Hi Gizzeta,
Sorry for the lag, i saw you'r question but have to take the train to go to the electrolyse days (was so geat
There is no static or global variable exposed in the SDK actually, so it's not coming from here.
We have to confirm with Senso if there is some at usine level (not exposed at SDK level), but even if there is some, it shouldn't make problem with a user buffer declared at the SDK level.
I tested with two instances of the C++ DrawPad user module and there is no problems with the point buffer.
Anyway, it's difficult to answer or help without some code for this kind of problem. It would be interesting to see how you declare, init and modify you'r buffer.
to load several instances of the same module you have to check if you have global variables declarations.
in this case the variables are shared between all the instances.
so try to create them into the TModule object declaration.
Hallo,
I declared the variables in the TModule class declaration:
and i created it in the create
What's the mistake?
thanks
Code: Select all
class TCycle : public TUserModule
public:
// Declare all parameters events pointers needed, example :
TEVT* pFreqIn;
TEVT* pAudioOut;
TEVT* ARR;
FILE* pFile;
float* buffer;
int* lSize;
};Code: Select all
void Create(void* &pModule) {
pModule = new TCycle();
TCycle* pCycle = ((TCycle*)pModule);
size_t result;
pCycle->lSize = new int;
pCycle->pFile = fopen ( "E:\AUDIO\USINEfiles\Cycle\Sine2048.bin" , "rb" );
assert(pCycle->pFile != NULL);
//obtain file size:
fseek (pCycle->pFile , 0 , SEEK_END);
*pCycle->lSize = ftell (pCycle->pFile);
*pCycle->lSize /= sizeof(float);
rewind (pCycle->pFile);
// allocate memory to contain the whole file:
pCycle->buffer = new float[sizeof(float)**pCycle->lSize];
// copy the file into the buffer:
result = fread (pCycle->buffer,sizeof(float),*pCycle->lSize,pCycle->pFile);
//close
fclose (pCycle->pFile);
}thanks
all of them?
are you sure there is no global hidden variables somewhere?
martignasse
hi Gizzeta,
the buffer pointer variable seems ok,
the use of fread too,
the only thing not very clean is that :
You not need a pointer to int in this case, just an int is enough :
It's lot more safe and make you'r code more readable, here the create modified tu use an int instead of a pointer to int :
this line is especially suspect and not very readable with these two *
you can already change that and see if it help.
but other than that, it's seems ok.
Code: Select all
int* lSize;Code: Select all
int lSize;Code: Select all
size_t result;
// no more needed
// pCycle->lSize = new int;
//obtain file size:
// no more * indirection
// especially this line was maybe missinterpreted before, it's better like that
pCycle->buffer = new float[sizeof(float) * pCycle->lSize];
result = fread (pCycle->buffer, sizeof(float), pCycle->lSize, pCycle->pFile);
//close
}Code: Select all
pCycle->buffer = new float[sizeof(float)**pCycle->lSize];but other than that, it's seems ok.
Hi, thanks for your help,
I found the problem.
I have others variables declared in the process function. I thought that theese were not global...(isn't it?)
So, I declared all the variables (with pointers) in the "TModule" and "create" functions and then i use them in the "process".
Now it seems to work fine.
But it's strange: i tried to do a simpler object with just one variable declared in the "process" without pointer (just for testing).
If i create 2 instances of this object the variable is not shared, while in my more complex "cycle" object, 2 instances share the variables with the same name...why?
however thanks
however thanks
martignasse
yep, strange
but in fact, without shown code, those bugs are very difficult to found. There is surely something in your 'more complex' object that is to obvious to be seen by you (lots of internal automatism when coding), but easily by another one, i mean, someone who not wrote the code !
The most important is that you solved your problem, so
that's my code (not so complex...), if you can help me to understend my mistake :
In the not working version the variables "index", "coefFreq" and "freqMinus" were declared as normal variables(not pointers) in the "process" function. They were shared by differents instances of the module.
Normally if I declare a variable in the process function, it's not global in Usine, isn't it?
Code: Select all
public:
TEVT* pFreqIn;
TEVT* pAudioOut;
FILE* pFile;
float* buffer, *index, *coefFreq, *freqMinus;
int* lSize;
void Process (void* pModule) {
//pointer to the module
static float samplesOverSR = (float)*(pCycle->lSize) / (float)pCycle->pMasterInfo->pTimeInfo->sampleRate;
int i;
pCycle->pAudioOut->len = pCycle->pMasterInfo->BlocSize;
// data type CONNECTED
if(pCycle->pFreqIn->len == 1){
if(pCycle->pFreqIn->value != *(pCycle->freqMinus)){
*(pCycle->freqMinus) = pCycle->pFreqIn->value;
*(pCycle->coefFreq) = pCycle->pFreqIn->value * samplesOverSR;
for(i = 0; i < pCycle->pMasterInfo->BlocSize; i++){
pCycle->pAudioOut->DATA[i] = *(pCycle->buffer + (int)*(pCycle->index));
*(pCycle->index) += *(pCycle->coefFreq);
if(*(pCycle->index) >= *(pCycle->lSize)) *(pCycle->index) -= *(pCycle->lSize);
// audio type CONNECTED
else if(pCycle->pFreqIn->len == pCycle->pMasterInfo->BlocSize){
if(pCycle->pFreqIn->DATA[i] != *(pCycle->freqMinus)){
*(pCycle->freqMinus) = pCycle->pFreqIn->DATA[i];
*(pCycle->coefFreq) = pCycle->pFreqIn->DATA[i] * samplesOverSR;
pCycle->pAudioOut->DATA[i] = *(pCycle->buffer + (int)(*(pCycle->index)));
// NO CABLE CONNECTED
else{
for(i = 0; i < pCycle->pMasterInfo->BlocSize; i++) pCycle->pAudioOut->DATA[i] = 0.f;
pCycle->pFreqIn->len = 0;
size_t result;
//obtain file size:
*(pCycle->lSize) = ftell (pCycle->pFile);
*(pCycle->lSize) /= sizeof(float);
pCycle->buffer = new float[sizeof(float)*(*(pCycle->lSize))];
//variables declaration and initialization (used only in "process" function)
pCycle->index = new float;
*(pCycle->index) = 0.f;
pCycle->coefFreq = new float;
pCycle->freqMinus = new float;
*(pCycle->freqMinus) = 0.f;
//close
void Destroy(void* pModule) {
delete pCycle->lSize;
delete pCycle->buffer;
delete pCycle->index;
delete pCycle->coefFreq;
delete pCycle->freqMinus;
delete pModule;
}Normally if I declare a variable in the process function, it's not global in Usine, isn't it?
...forgot:
lSize is a pointer because I need to access to it in the process function. It's the only way, isn't it?
martignasse
no problem, but remenber to ask someone else to read your codeGizzeta wrote:...forgot:
no, there is no need to make complex things like that.lSize is a pointer because I need to access to it in the process function. It's the only way, isn't it?
the process function provide one parameter, a pointer to void who is a pointer to your user module, you have just to cast it conveiniently.
Code: Select all
TMyModule* pMyModule = ((TMyModule*)pModule);Code: Select all
nt local_int_value_of_lSize = pMyModule->lSize;Code: Select all
pMyModule->lSize = 3;generally, pointer are conveinient for composite variable (like structure, or class) which is not the case of an int.
hope it enlight you
Yes, very precious for me, thanks!
...maybe you haven't seen my previous post...I have put the whole code...no problem, but remenber to ask someone else to read your codeit save days, no joke !
martignasse
sorry, i didn't saw the post from 20.55. :rolleyes:
martignasse
ok, after read your code, i have some other questions/clarifications/advices
1°)
the fact you declare the 'samplesOverSR' variable static make it initialised only one time, at the first execution of the process function, and because declaration and affectation is one the same line, 'samplesOverSR' is never updated with the '(float)*(pCycle->lSize) / (float)pCycle->pMasterInfo->pTimeInfo->sampleRate' result.
More than that, as 'samplesOverSR' is declared static, only one instance of it is shared by all instances of your modules.
Is it the intended behavior ?
2°)
What kind of datatype is your 'pFreqIn' param ?
It seems you use it sometime for data, sometime for audio buffer (strange and potentially dangerous) but i can't see what kind of param is used, array maybe ?
3°)
in general, your code is hard to read and understand, i can't even know what you exactly do just by reading it
Try to let things simple and clear. For this, here some general rules :
- one meaning by variable, it preserve you from unwanted side effect and make readability better, for example, 'pCycle->pFreqIn->len' is initially used to store the size of the DATA array of 'pCycle->pFreqIn', but you use it also to detect if you make data or audio treatment.
- avoid duplication of same code, for example, you surely can avoid the double time use of this block (used in your 'if' AND 'else' statement)
it's easier to maintain and fr bug tracking.
- reduce the use of class/structure member call for reading info in 'for' loop, make variable for it before the loop, for example
it make code more readable and optimized, if your BlockSize is 512, you save 512 class/structure member calls.
Hope it help
1°)
Code: Select all
static float samplesOverSR = (float)*(pCycle->lSize) / (float)pCycle->pMasterInfo->pTimeInfo->sampleRate;More than that, as 'samplesOverSR' is declared static, only one instance of it is shared by all instances of your modules.
2°)
3°)
Code: Select all
if(*(pCycle->index) >= *(pCycle->lSize)) *(pCycle->index) -= *(pCycle->lSize);- reduce the use of class/structure member call for reading info in 'for' loop, make variable for it before the loop, for example
Code: Select all
int iAudioOutLen = pCycle->pAudioOut->len = pCycle->pMasterInfo->BlocSize;
int i ;
for (i = 0; i < iAudioOutLen ) {
}Hope it help
Hi Martignasse,
The module is a simple oscillator. It fill a buffer with a file where there's a one-cycle waveform.
Then it calculates wich sample he has to put out, according with the actual frequency parameter.
1°)
Maybe can I initialize it in the "InitModule" function?
Can you explain me the exact order in wich the finctions are called by Usine? (I guess: "Create", then "getModuleInfo", then "initModule"....)
So a variable declared as static is shared by all instances? (I'm sorry, I'm a c++ beginner...)
And if I want a variable, private to the module, that keep the value between more functions calls, I have to declare it in the "create" function? And it can be a normal (not pointer) variable?
2°)
So, if the incoming data is a single value (len == 1), it's a normal data frequency control. In this case I calculate (pFreqIn*samplesOverSR) just once for "process" call.
If the incoming data is an array whose lenght is the same as Block Size, it's a frequency modulation and (pFreqIn*samplesOverSR) has to be calculated once for sample.
Finally, if there's no cable connected, I want the module to out a 0.f signal (silence).
3°)
Empircally, I found that I have to set to 0 the 'pCycle->pFreqIn->len' at the end of each "process" call. Otherwise if a cable is not connected, it keep the last lenght.
really thanks for your counsels!
1°)
that's what I want. lSize/SR is always the same, for all the module duration. I calculate it only at creation, to economize CPU.martignasse wrote:'samplesOverSR' is never updated with the '(float)*(pCycle->lSize) / (float)pCycle->pMasterInfo->pTimeInfo->sampleRate' result.
I thik this was my problem...More than that, as 'samplesOverSR' is declared static, only one instance of it is shared by all instances of your modules.
2°)
It's a pDataFader. Because I want that it could be possible to control the module frequency by a data value and by a signal value (for frequency modulation, eg: at every sample the frequency value can variate).What kind of datatype is your 'pFreqIn' param ?
3°)
..hem...I don't understend...I detect what kind of message (data or signal) is coming in, by the size if the 'pCycle->pFreqIn'.'pCycle->pFreqIn->len' is initially used to store the size of the DATA array of 'pCycle->pFreqIn', but you use it also to detect if you make data or audio treatment.
Do you think it's better to create a function on purpose?- avoid duplication of same code,
In term of CPU economy what is more expensive: a class/structure member calls or a variable more?- reduce the use of class/structure member call for reading info in 'for' loop, make variable for it before the loop, for exampleit make code more readable and optimized, if your BlockSize is 512, you save 512 class/structure member calls.Code: Select all
int iAudioOutLen = pCycle->pAudioOut->len = pCycle->pMasterInfo->BlocSize; int i ; ... for (i = 0; i < iAudioOutLen ) { ... }
martignasse
ok, it's what i supposedThe module is a simple oscillator. It fill a buffer with a file where there's a one-cycle waveform.
Good question, i dont know the exact order, but i'm sure of that :Can you explain me the exact order in wich the finctions are called by Usine? (I guess: "Create", then "getModuleInfo", then "initModule"....)
1/ Create
2/ InitModule,
3/ Process <- called each Usine cycle (800/second) while your module is alive
4/ Destroy
eventually:
CallBack is called by usine each time a param is modified in the module parameters panel
for the rest, i 'm not sure, i'll try to make a time sequenced diagram in the wiki,
Yep, static variables are created in the static memory, shared by all functions (don't miss the SDK interface is C, not C++)So a variable declared as static is shared by all instances? (I'm sorry, I'm a c++ beginner...)
the simple way is to declare it in your module definition (the include file), and initialise it in the InitModule function if you need some infos stored in pMasterInfoAnd if I want a variable, private to the module, that keep the value between more functions calls, I have to declare it in the "create" function? And it can be a normal (not pointer) variable?
in the include file :
Code: Select all
class MuModule : public TUserModule
private:
int iMyVariable;
};Code: Select all
// initialisation
void InitModule (void* pModule, TMasterInfo* pMasterInfo, TModuleInfo* pModuleInfo) {
// conveinient pointer
MyModule* pMyModule = ((MyModule*)pModule);
// remember, it's up to us to initialise the pMasterInfo poimnter herited from TUserModule
pMyModule->pMasterInfo = pMasterInfo;
// initialisation of other variable
pMyModule->iMyVariable = pMasterInfo->pTimeInfo->sampleRate; // or whatever, you got the idea
...well, it's here your design is not very clear, i think, you have two signification for the same param, it's not clean.It's a pDataFader. Because I want that it could be possible to control the module frequency by a data value and by a signal value (for frequency modulation, eg: at every sample the frequency value can variate).
What prevent you to split that in two param ? like a 'base freq' one who is a value of the wanted reference frequence and a 'mod' one who is a signal of the modulation wanted around the 'base freq' value.
but Usine provide different params for differents kind of signal, like said above. seems like your design push you to make extra work here.I detect what kind of message (data or signal) is coming in, by the size if the 'pCycle->pFreqIn'.
not automaticly, for your case, it's once again the design who push you to make like that. In your Process function, there is some mix between the detection of the param (data or signal) and the audio treatment, it make the code trickyDo you think it's better to create a function on purpose?
I profit by your patience...
ie. if the block size is 128, audio process is called every 128 samples?
Or, if the sample rate is 44100 and "process" is called 800/sec, the audio array is around 55 samples?(but, normally, it can't be less than the block size)
thanks again
"process" is called syncronicall with the block size?martignasse wrote:3/ Process <- called each Usine cycle (800/second) while your module is alive
??? sorry, I don't understand: this SDK is C++, right? What do you mean with SDK interface?(don't miss the SDK interface is C, not C++)
that's true....What prevent you to split that in two param ? like a 'base freq' one who is a value of the wanted reference frequence and a 'mod' one who is a signal of the modulation wanted around the 'base freq' value.
thanks again
martignasse
oups, missed the response,
I'm impatient to see your modules
seems you've got confirmation from senso in the other thread that the process function is called every BLOC samples. I prefer that the info come from senso, as he is the one who know all that stuff, i'm like you, discovering the beast (not senso...Usine"process" is called syncronicall with the block size?
yep, the SDK itself is in C++, but the brunch of functions to communicate with usine (at the end of the UserDefinitions.h) use C signature. Anyway, not very relevant, should be pretty tired when i wrote that, sorrysorry, I don't understand: this SDK is C++, right? What do you mean with SDK interface?
the process is called every BLOC samples, (see setup/best bloc size).
more precisely Usine call process each time we need to calculate BLOC number of samples.
but don't forget that there is a time jitter, due to the sound card latency and the multi thread core. For example Usine can process 2 blocs very quickly and then wait few ms before treat another set of 2 blocs...
martignasse
For knowledge durability reasons, you have to know that important informations evoked in this conversation are now wikified.
wiki::sdk::usine architecture
Of course, you have rights and duties to consult, modify and make alive these informations
Users browsing this forum: No registered users and 64 guests
