osc in global interface control
lalo
Unread post by lalo » 28 Apr 2009, 22:51
hi,
would be really confortable to have osc control on global interface control...
so i could use my ipod touch with touch osc to control the usine mixer with any patch loaded
thanx
lalo
Clearscreen
Unread post by Clearscreen » 29 Apr 2009, 00:31
how do you mean? like an 'OSC learn' similar to 'midi/key learn'?
lalo
Unread post by lalo » 29 Apr 2009, 00:48
no...
i mean just a field in wich insert the osc command that control the particular parameter
Unread post by nay-seven » 29 Apr 2009, 07:19
in " inputs/outputs" you have a new module named " send midi to usine"
so you can build a patch that send osc to midi to any parameters of Usine , as the mixer ones...
ethnix73
Unread post by ethnix73 » 29 Apr 2009, 08:36
Can't you use the OSC receive module with the module "mixer input" and "mixer output"?
Seb.Dub
lalo
Unread post by lalo » 29 Apr 2009, 10:25
ethnix73 wrote:Can't you use the OSC receive module with the module "mixer input" and "mixer output"?
yes...but in this way i have to do it for every patch loaded in the track slots....
i'd like to have a thing that is valid for every patch loaded in the track in every slot
Unread post by bsork » 29 Apr 2009, 11:38
You could create sort of a "master" patch that's always active - where the patch resides doesn't matter. You could for instance put it into one of the master in-/output patch slots.
Unread post by senso » 29 Apr 2009, 12:33
I'm not sure I understand your pb.
personally I use the bsork solution:
a kind of OSC master patch which distribute osc values via data buses.
