A Recorder as a Midi Breath Controller: Succesfull
marcielo
Unread post by marcielo » 26 Apr 2009, 07:31
Just want to share with you that im using succesfully Usine for a "simple" task: a breath controller. It works great and quick! im very happy i can record some tracks with it, instead of playing with the keyboard and then drawing controllers over all the track.
Thanks very much for this program!
http://www.youtube.com/watch?v=CRo-HG3SQMk
A poor video from me, but shows the idea working. Sorry my spoken english
runagate
Unread post by runagate » 26 Apr 2009, 08:05
That's amazing. I got a EWI USB this year but I rock the hell out of the recorder... I might have to go pick one up. I've had one of each size from bari to sopranino in the past. Such a strange instrument. I like to make multiphonic broken chords with them myself ;-)
Thank you very, very much marcielo!
marcielo
Unread post by marcielo » 26 Apr 2009, 08:15
You are welcome.
I really want to thanks Mr. Olivier about the amazing program.
ethnix73
Unread post by ethnix73 » 26 Apr 2009, 12:39
Really interesting marcielo. i've just started what you've done, but with a melodica, and i haven't been yet sucessfull.
Do you use only the "audio to midi" patch from Usine?
Could be really helpful for me to have further more info on your workspace.
Seb.Dub
marcielo
Unread post by marcielo » 26 Apr 2009, 16:44
Hi! It takes me some time to figure this thing working out, but after it was done, is very easy to use, since you simply load the preset.
I created a workspace that use the "Audio2midi" modules of Usine and a bunch of free plugins with them. The free plugins are Kjaerhus compressor, GSnap and GTuner (both them help tune your audio input, so is more easy for the "Audio2midi" modules recognize the note you are playing) and "Soma enveloper" a powerfull plugin that converts the amplitude of an audio source to Midi CC.
So, after you save all this routing, you load Usine as a VST fx in an audio Track of your host, route the midi output of this track to Kontakt, and you are done.
What i can do with this:
Convert mono audio 2 midi notes (i believe that the accuracy, using a recorder at least, is ~90%. If i sing the recognition is worst, because im not a good singer, but also because recorder tones are more "pure" with no so high armonic content like other instruments)
Convert amplitude of the audio signal to any midi CC. So, if you assigned it to the ModWheel, and you are using GPO, while you record the notes, you can record the intesity of that notes. You only need to care to press the pedal for legato/non legato.
Firstly, i make the experiment just by curiosity, but it`s working so well, that i will use it for daily work.
If you want to see how the "Usine" workspace i made looks, here are two links:
(i put the images as external links since they are a little big, and mess the forum)
http://stashbox.org/499038/Workspace1.jpg
http://stashbox.org/499041/Workspace2.jpg
ethnix73
Unread post by ethnix73 » 29 Apr 2009, 00:13
Thanks for your answer and the two screenshots marcielo.
Seb.Dub
Unread post by grego mondo » 29 Apr 2009, 14:40
thanks for the tips, it will help, I'm building an intelligent pitch (kind of a harmonizer responding to a scale !!)
marcielo
Unread post by marcielo » 30 Apr 2009, 00:39
grego mondo wrote:thanks for the tips, it will help, I'm building an intelligent pitch (kind of a harmonizer responding to a scale !!)
It sounds very interesting. Tell us later!
regards
Users browsing this forum: Bing [Bot] and 185 guests
