Usine 4.20 beta6 important bug fixed & Quad-Core optimization
Announcements
Unread post by senso » 21 Apr 2009, 10:26
[4.2 beta 6]
Multi-Core Version
Important VST bugs solved.
improvements
- Quad-Core optimization
fixed bugs
- important bug when loading VST's
[4.2 beta 5]
Multi-Core Version
Major release with more than 100 improvements.
This is probably the most stable Usine we never had but is still a beta version because new real multi-core optimization.
Take a look on the demo files to have an idea of what we can now do with Usine, especially in personal interface design.
improvements
- real Multi-Core CPU optimization
- auto reorganization of windows in the interface builder: It's an option of the IB layout (see the manual)
- new dashboard and master synchro design,
- auto show option in the conductor lite window
- new midi mode option "Interface builder windows order"
- get buses list module
- current patch name module
- the key-learn steps on fader are proportional to the key stroke speed.
- new option in the visible parameter of controls like fader, switches, etc: set the position 'parent Interface builder'.
- new 'Mouse pressed' & "double click" outlets in the Image and Text (comment) modules
- new 'Mouse X' and 'Mouse Y' outlets in the Image module to get the Mouse position on the
- new layouts options in the Interface Builder
- in global Interface navigation bar, you can adjust the number of speed buttons to display.
- new 'Send Midi to Usine' module which sends midi data to Usine itself, exactly like if it was send from an external midi device.
- new inlets in the dashboard module to show the setup or the waveplayer windows.
- midi out module can send codes to different channels at the same time
- new color inlet in the Button module
- vertical scroll enabled in the interface builder
- easy move wire mode in patch
fixed bugs
- the show remote button [R] doesn't work properly
- Timer bug on the navigation bar (touch screen mode)
- various run time errors in the FFT inverse module.
- the VST windows position are now memorized
- many GUI bugs and details solved.
compatibility notes
- the new channel management of the midi out module can cause some backward compatibility problems.
amiga909
Unread post by amiga909 » 21 Apr 2009, 11:29
great!!!!!
thanks a lot.
among many other features interactive interface design is getting bloody serious!
amazing u could realize the multicore thing, I am stunned.
gurulogic
Unread post by gurulogic » 21 Apr 2009, 11:36
I am having some audio problems with quad core...but I have to sleep now so in the morning I can have a fresh head and not make Senso chase any false bugs that are probably my own fault ;)
Users browsing this forum: No registered users and 170 guests
