first try of faders design
Unread post by 23fx23 » 18 Apr 2009, 01:48
I start to try also differents lemur style faders:
little 1,5mb quicktime MP4 vid:
http://www.sensomusic.com/forums/upload ... efader.mp4
just thougt a 128 frames files would be around 12800 pixels large in full rez, will usine handle such loading in real time?
(before i start to manually offset 128 frames manually in a single jpg ;)
edit: mmm seen included ones are on 32 frames, maybe 32/64 is enough, and gonna half the rez, when i ll find how to "fill them"
does anybody has a tip to speed up process to put incremental frames side by side with software?
Unread post by nay-seven » 19 Apr 2009, 15:06
they're really nice !
but i will be afraid about the resolution..
i've yet some problems with graphics time to time...
Unread post by 23fx23 » 19 Apr 2009, 15:53
thx nay, yes understood rez has to be "descent", either less step in high rez, or less rez.. though could do nice things with less data if there were a way to layer and have additive/multiply/transparency mode but it's not usine main goal i guess..I prefer it to be fast, and i love "industrial" basic too, just so waiting rounded corners of V5 ;)
Unread post by 23fx23 » 20 Apr 2009, 17:13
uploaded 3 versions faders in 2 size in add/ons/ template, made 32 frames half rez, tested working fine:
Unread post by nay-seven » 20 Apr 2009, 18:14
just tested here , works fine
one thing : save the preset ( ex : fader1-32 35-170.FaderV ) with the jpg file...better for users...always lazy boys..
and now you have to do a complete set !!
Unread post by 23fx23 » 20 Apr 2009, 18:33
oops yeah didn't saw save the preset fuction.
il try to rewrite the file with more with time :) were made in 2d soft, working on 3d version also.
fractal
Unread post by fractal » 25 Apr 2009, 18:29
I try but : i fail ! lol
Any good tutorial?
I'm not very familiar with fader/button customize... i download the files put in 'skin'> open in edit layout of my fader but i have a huuugee fader lol with all the frame...
and i want this fader ,they are so beautiful.
Unread post by nay-seven » 25 Apr 2009, 19:28
i suppose you need to set the number of frames :
you can , of course , choose also "show caption " and show value "..
then , save preset ;-)
Unread post by 23fx23 » 25 Apr 2009, 20:47
glad u like it fractal,im working on buttons on pots,and other (pause now , back to sound), will save the preset :) in future,
yup I guess you have to type with keybord "32" in frames, then disable fader, caption and value as pointed by nay.
fractal
Unread post by fractal » 25 Apr 2009, 23:33
Thank you Nay-seven and 23fx23 !
this work like a charm !!!
I'm so stupid sometimes ;)
I'm fighting with the 'frames count' (when you select with the mouse you never have 32....only 31, 33 ,35... ahahaha i go mad until i read : "put 32" after a double click on it > taataaa ! 32 with my keyboard ! )
i can spend my night to re-design my volumes fader , yeah !!!
23fx23: can't wait for the other stuff ;)
Unread post by 23fx23 » 26 Apr 2009, 00:47
hehe i undestood after why included ones where in 31 frames only :)
Users browsing this forum: No registered users and 664 guests
