error : bad virtual midi out device
julien_
Unread post by julien_ » 23 Mar 2009, 01:01
hi all,
i got a problem with a cc filter patch.
if i open it as a patch, it works
if i open it as a sub patch, it doesn't
one thing i notice is that the midi in device is different.If i open it as a patch, midi in device has more options
and each time a move my controler, there is this message in the statuts bar :
anyone has this probleme too ?
thx
julien_
Unread post by julien_ » 23 Mar 2009, 01:54
actually no problem with that..just a wrong configuration
but always i still a big problem with midi input in a sub patch !
someone could test ?
http://jjuull.free.fr/usine/
thx
Clearscreen
Unread post by Clearscreen » 23 Mar 2009, 05:29
that patch seems to work ok here - the midi is going into it without a problem. are you having a problem getting midi into the sub patch?
the midi input module will be slightly different depending on whether it's inside a sub patch or in a tracks base patcher view. when you move it inside a sub patch you lose everything below the 'receive' socket - i'm not totally sure why, i'm assuming to keep things a bit neater. what it means in use is that you need to connect a base level midi input (which will talk to your midi hardware) to the blue midi socket on the sub patch. if you CTRL+click+drag you will also get a menu of some commonly used items that will connect with that socket that may be useful for you. hope this helps somewhat, otherwise see if you can explain your problem again - best of luck!
Unread post by nay-seven » 23 Mar 2009, 07:52
hum...same for me here , not sure to understand...
the "midi data out " work when i choose "midi" in the List button , not when i choose " manual"...( patch or subpatch )
is this the problem..?
julien_
Unread post by julien_ » 23 Mar 2009, 22:19
i didn't plug the midi in device before the subpatch ..........
no comment....
thx for your answers
