Draw trajectory example.pat in The User/Examples folder doesnt accept the functionnality of Preset manager 8* or 16*
I m using it for a installation to spatializate the sound between 12 speakers, i need playing different sequences of spatialization and i used trig on preset manager...
Is it normal ?
Have you got different Solution to help me
I can send my patch if thats interest something...
Excuse for my dirty english writing, i learn
Simonakimou
and I do a festival with friends Is na,e is Kontact Sonores at Chalon Sur Saone (France Burgundy Saone et Loire 71)
http://www/kontactsonores.com
The Vienna Vegetable Orchestra, Computer Truck (circuit bending); Pierre Bastien, Pierre Jodlowski, OttoannA, Aymeric de Tapol, Jean Marc Weber (remember Senso you maked a workshop at chalon Sur Saone) and lot of installations musical and playful of rapahel ISdant
http://raphael.isdant.free.fr/
THks Usiners
Draw trajectory example .pat don't accepted Preset Manager
don't think it's possible right now , cause no inlets , maybe ask to a guru script to add some...?
if you can deal with an xy pad with his record function , something like this works :
ps : your work is really beautiful ( artefact )
artefact is not my work
Im not raphael isdant
thanks lot i will try...
hey im from chalon sur saone too, but work in paris, will try to be there the 24!
Et bien avec plaisir sa va envoyer du bois...23fx23 wrote:hey im from chalon sur saone too, but work in paris, will try to be there the 24!
Users browsing this forum: No registered users and 74 guests
