Going Usine after XT2?
Rottweiler
Unread post by Rottweiler » 07 Mar 2009, 00:09
hi guys!
im an XT user, can i replace xt with usine? i mean is there any easy-to-use sequencer in it?
Clearscreen
Unread post by Clearscreen » 07 Mar 2009, 03:20
there's a few different easy to use sequencers. theres a DAW style sequencer view (kinda like the xt sequencer view) and a couple of different modular style loop sequencers including a step sequencer midi module and a piano roll - download the free version and give it a go - usine doesn't have a big install routine, you just run it once you've unzipped it and it starts so you've got nothing to lose :)
Unread post by nay-seven » 07 Mar 2009, 10:03
hello and welcome , there's also some user patch you can access later if you like Usine , like this one:
Rottweiler
Unread post by Rottweiler » 07 Mar 2009, 11:20
will try and report back later :) thanks
easy
amiga909
Unread post by amiga909 » 07 Mar 2009, 11:55
xt has an amazing piano roll.
if u rely on xt for composing, u could use xt 1.x (playing midi tracks) inside usine?
Rottweiler
Unread post by Rottweiler » 07 Mar 2009, 22:22
i never used xt1, and i try to avoid these hybrid solutions, but ty for the tip.
Users browsing this forum: No registered users and 585 guests
