hi guys! (still no girls?)
i tried the 16 bars syncro mode in the sampler,but it work:s strangely or the sampler record 14 bars and begin to play before i stop to record,or it records the sample entirely and begin to play,but instead of reading it from the beginning to the end,it reads the first bar and come back to the beginning to read it normally,so it's not well sincronized....or is it according to the total bars played?
any ideas? thanks...
syncro ?!
the module plays sample every 16 bars since the patch has started.
so, if you use it to record on the fly long sample and the recording doesn't start at the first bar and doesn't stop at the end of the 15th you will have strange results...
try to use 'live kits' of the library instead.
i deducted something like that,so i use the punch in grain ,thanks for your answer...
