Hi
a simple suggestion to implement in USINE :
Send all notes off before switch OFF Usine.
Because actually when you switch OFF Usine and MIDI data are sent to external machines the notes stay ON. I'm oblige to stop Usine when is not reading a MIDI note.
Charles
Sending All note Off before switch off Usine
- nay-seven
what about this :
global midi and key learn ( ctrl F4 ) : assign space bar( or whatever else ) to dashboard stop and to dashboard Panic...?
cybercharles
Hi
as usual USINE can do everything !
I will try this solution to night and give you the feedback.
Charles
Charles
t
- senso
good tip also for me!
