Joystick module with support for more than 4 buttons?
just check the addons section /others :
named Joy_X16
patch +dll ( to install in your vst folder ), usefull to use a joystick as controller .
add 3 axis , Z-rotation, 2 direction pad , 2 sliders, and 16 buttons support
must be compatible with most of gamepad and big joystick
wiki page is here :
http://www.sensomusic.com/wiki/doku.php ... rs:Joy_X16
tell me if it's ok for you...
named Joy_X16
wiki page is here :
Thanks!! i've read both answers, your add-on seems fine for me - now i just need to buy a USB joystick
cheers, Goyya
cheers, Goyya
hello,
I cannot open the zip file for the joystick, it says "corrupted". I tried with winrar and winzip unsuccesfull !
jmw
jmw
FWIW, I downloaded and extracted the file without problems with Winzip.
download it directly from 'add-ons / others'.
should work
should work
Users browsing this forum: No registered users and 70 guests
