Renaming 'USB Audio Device'
Stefan
Unread post by Stefan » 25 Jan 2009, 11:10
I have a question regarding windows: is it possible to rename the USB Devices in windows? I have several Midi Devices (BCR2000, padKontrol, Evolution Keyboard, FCB1010) and they all show up as "USB Audio Device" in Usine (or USB-Audiogerät, since my windows speaks german). Does anybody know if it´s possible to rename them?
Stefan
Vincent
Unread post by Vincent » 25 Jan 2009, 11:50
Good question.
If anybody can answer to that, we'll be at least two to appreciate!
vincent michel
composer & novelist
Unread post by nay-seven » 25 Jan 2009, 13:16
! , really strange problems ...i've bcr2000 and others , all have their complete name...
which windows do you use...?
have you try to uninstall /reinstall them..?(reel uninstall , drivers first and so..)
Stefan
Unread post by Stefan » 25 Jan 2009, 13:48
Hi nay-seven,
I am using WinXP SP3. Reinstalling the drivers (if any) does not help. It´s strange, I have a little programm called USBDeview and it shows the correct names. But in my DAWs the midi gear only shows up as USB Audio Device.
@vincent: at least, I´m not alone. :)
Cheers, Stefan
Unread post by senso » 25 Jan 2009, 20:52
no way!!!
it's a windows pb that I can't solve myself.
but be patient in windows7 there devices appears with their real name.
Users browsing this forum: No registered users and 191 guests
