conflict between somepatches and a synchro master
Unread post by grego mondo » 20 Jan 2009, 10:05
Hello, still using the 4.01e ...
I made a kind of simple sequencer, changing tempo and cycle lenght ... it works fine
so I have two cycle of 16 mesures and then two cycles of 17 measures, works fine ...
and then I when add some patches like AFX total Seq or others, the cycle never goes to 17 ...
17 goes to the synchro master inlet (and goes out to the lenght of a step sequencer ...) but in the master synchro section it stays 16 ...
Am I misunderstanding something or is it a bug ?
Unread post by bsork » 20 Jan 2009, 10:21
I haven't looked at the AFX, but I guess that patch also connects to cycle length creating a conflict with your sequencer patch. Without testing I can't be sure, but my guess is that when two patches try to control the same (global) value, the last one will be used. I suspect that Usine calculates the patches sequentially starting with the inputs, then track 1 from the top down, track 2 likewise etc before going to the outputs. Whether the sequencer patches are calculated before or after the grid, I (also...) don't know, but I suspect the grid comes first.
Unread post by grego mondo » 20 Jan 2009, 10:27
Thanks ...
I had the same problem with another patch (but I can't remember witch one) that was in track 1 and my synchro module was in the last track .. .
thing is when I look in the AFX I don't see any sync module ...
Simonaki
Unread post by Simonaki » 23 Jan 2009, 04:20
I've the same Problem, when i take two different module of master Synchronisation in two different patch in two different track that makes trouble...is it Normally? If i take Local synchronisation but i want that is synchronised to the master Synchro is it possible?
Sorry Dirty English
Because my big research is how can i loop two different step with two different lenght but at the same beat? i'm just looking to enlarge a step when i want but not accelarate him...that's it happen when i enlarge the size of the steps..
And i've got a probleme with the "general time bar" it doesn't reset when i'm go back to the start of sequencer. Is it normal too?
Thanks Usiners
Unread post by senso » 25 Jan 2009, 20:58
It's probably because in some patch there is:
- another synchro module with it cycle length connected
or
- the AFX use an old version of the synchro module (Master synchro (hi cpu)); just replace the old module by the new 'low cpu' version and it should rock.
Users browsing this forum: No registered users and 119 guests
