User Curve Don't play on Usine v4.1 beta 8
hello
i'm not a specialist about this module , so i've load " Demo05 - Sequencer (easy percs) " in the last beta
looking for user curve in the sequencer and all seems ok for me...?
Hy every body
I d'on't have resolved my probleme i'm not crazy, i've try with old version thats work fine but with this new version , no way.
I explain again my problem: when i create usercurve module direct from the cut off's helios for exemple in a empty sub patch on the sequencer i just see " " on the module user curve and user 41 on sequencer and nOT Cut off...so did you have teh same probleme don(t try just a demo ,make yourself a sweety patch for look.
Perhaps i'm making a big stupid mistake of configuration, apologize me for my dirty english
Simon
Simon
I just tried this in 41Beta8, and it worked. You have to choose which curve the User Curve module is for after creation though (hence the missing text). The HeliosII has two CutOff parameters, not sure what the first one is for, but I got the second working ok with the knob on the GUI following the curve, etc.
Just for the record, I have only the included templates. Have you made your own, maybe?
Yes i've made myself the user curve so it's a real problem...I use 4.01 for the moment
can you make a simple workspace illustrating your way and upload it somewhere..?
here how i made mine :(beta8)
open sequencer mode , track 1 , add a midifile,click on user1, rename it to " test"
doubleclick on the midifile event to open it , add the module usercurve , choose the the curve "test"
add a "bus "send to audio,data"
route to whatever you want...
sorry but I do not understand your last sentences,can you try with other words ...?
or maybe we can also use this forum :
http://forums.audiofanzine.com/index,id ... usine.html
the next beta will contain a new template to crate user curves automatically.
Hy nay seven, sorry for my english,
Senso understand my problem,he will add automatic user curve in futur version, thanks a lot to reply me...
Thanks Again
Thanks Again
Users browsing this forum: Google [Bot] and 22 guests
