Fade in/out to avoid clicks when bypassing/muting
lalo
Unread post by lalo » 18 Oct 2006, 09:34
hi,
often during the liveset i have to mute or bypass an effect or in general an audio process...always a click came out...wich is a bit annoying for the aural
fascination of the performance :)
..how about infinitesimal fade in/out option to avoid this?
thanx
Unread post by senso » 18 Oct 2006, 12:28
I understant that it can be a problem for the "aural fascination of the performance"!
So I've implemented a very short fade In/out on track mixer buttons:
MUTE
SOLO
ON/OFF
In then next realase
For the Bybass Button on VST's things are more complex.
In that case, it's not a fadeIn/out but more a crossfade between incoming sound and processed sound. (the bypass on VST's means audio pass thru)
I recommend you to make it with a Crossfade or Volume module.
lalo
Unread post by lalo » 27 Oct 2006, 00:18
if you'll find a solution for vst crossfade i'll be happy :)
(i was able to convince bidule coders ;) )
thanx for the last great update man
Unread post by senso » 27 Oct 2006, 09:06
I will take a look.
In that precise case, if you can?t wait, try to make a sub patch which does the fade. (less than 2 minutes?)
Thanks for all your feedbacks.
They are very important for me.
Unread post by senso » 27 Oct 2006, 10:53
I will take a look.
Users browsing this forum: Bing [Bot] and 79 guests
