please add more examples
nelson
Unread post by nelson » 02 Jan 2009, 01:25
hi
1. please add more examples of code of real working modules using many different parameters and data types (for example sending midi messages, working with time & synchro... etc...)
2. how to read / write string from/to TextValue of ptTextField parameter?
pPrototype->PText->DATA[0] = .... <- all values here are float, how to write string to this textfile?
there is so small amount of examples - it produces questions like this above if I'm not so experienced C programmer...
please help :)
martignasse
Unread post by martignasse » 02 Jan 2009, 19:54
hi nelson,
before all, did you figured out your problem with array, in the other thread ?
Yes, off course, it's the way to go...
But as the CPP SDK is new, there is not a lot of examples for now. The WIKIis here for that, but everybody should put some content (i can manage the WIKI SDK part, but have not enough time to make all the stuff like examples).
It will come with time....I'll prepare a code snippets section for all datatypes types, feel free to put some code in, as you discover some things.
I even don't know myself, and have no time to test for now. the way to go is : test it with minimal user module... and if you're successful, put a code snippet on the WIKI.
please help :)
Yep, to be comfortable with C/CPP is a plus, but i'm sure we will arrive to make it accessible to beginners...with time
nelson
Unread post by nelson » 02 Jan 2009, 20:19
yes, thanx, its works fine ...
now im working on some L-System implementation and have already all the code in C++ from previous implementation but now I must to lern how to manage with this SDK ... how to get text values from input or from textField - rules for l-system.
ok. I'm waiting for some more examples...
Users browsing this forum: No registered users and 112 guests
