hello crazy usiners!
i like to use the" sampler force tempo",very usefull tool ,witch calculates your tempo according to the metric and the lenght of your loop ... but some problems are:the recorded loop does not begin just after recording,there is a kind o fbizarre latence,not the same from one loop to another,sometimes the loop begins to play before you finish to record,not very cool...
the second point is that your loop is automatically calculated as a cycle,and not as one bar,or half,or wathever you want....
maybe someone had the same problem...and solve it?
youpi!
"sampler force tempo" is a little hard....
It's probably a patching pb.
I'll take a look
I'll take a look
did you take a look? does someone can help me?no "sampler force tempo" users around here? damned......
The "sampler force tempo" is an old patch made with old usine objects.
there is no re-synchronization after the recording so the behavior you describe is normal.
maybe you can try to rewrite it totally?
but the question you have to answer is :
what to do after the recording?
- restart the synchro?
Users browsing this forum: Bing [Bot] and 30 guests
