button inputs to scripts
I am trying to check a button from a script, and I think I'm making it harder than it should be, and it doesn't work anyway.
Can anyone explain how to do this, or point me to a script that does it. I just want to have the script do something when the user pushes a button connected to an input.
Thanks!
-eric
Thanks!
-eric
I wasn't using a button input. But now I am, and it's still not working.....
IF (GetValue(pButton) = 1) THEN BEGIN
// To be on the safe side, add:
SetValue(pButton, 0);
END;
END;
Okay, I see my problem now.
I'd like to run my main methods in a slower event loop, but then I seem to miss the button presses. I tried to keep track of whether the button had been pressed since the last iteration of my slow loop, but I haven't figured out how to track that reliably.....
For now, I'm running at full control rate, but I worry a little about the processor overhead.....
Wouldn't something like this do the trick?
var ButtonPressed: boolean;
If getvalue(pButton)=1 then
begin
Setvalue(pButton, 0);
ButtonPressed:=true;
end;
You put this before your slow loop, then you can check the value of ButtonPressed inside the slow loop, without forgetting to do
ButtonPressed:=false;
before exiting your slow loop.
Hope it can help.
Rgds,
B.
begin
end;
Hope it can help.
Rgds,
B.
I see. Cool, I'll try that--the key is to set the buttonpressed back to false.....
thanks!
-e
thanks!
-e
i dont really unsderstand the use of button in script.
bsork, when you write
END;
i suppose the pButton you refer in GetValue(pButton) is an input button and the pButton of SetValue(pButton, 0) an outuput button.
an i wrong ? if i am not, it means the output pButton have never be in the 1 position before come back in 0 position.
if i write
inval := getvalue(inputbutton);
setvalue(outputbutton,inval);
there is no problem, the output button follow the input one behaviour
but between this two moments i want to make a lot of things.
I want to trig a button behaviour (1..0) on an output at the end of my script
i tried to put at the end of my script that i suppose to be the last performed code (?)
setvalue(outputbutton,1);
setvalue(outputbutton,0);
but i can only see the 0 in the output.
anyone can help me or to point me out a script without input/output correlation ?
thanks
END;
if i write
thanks
The pButton I'm referring to is the same parameter/variable both for input and output. What I didn't make clear, is that sometimes (may be bad programming, I don't know), the pButton is still 1 in the next execution block.
If I have understood things correctly, Usine won't update an input parameter unless something is passed along the "wire", so if you return it to 0 within the script somewhere after checking for 1, you can be sure that the code isn't executed repeatedly. (The p in pButton is jus my habit when naming the in/out parameters.)
Just for the record, a "proper" button message in Usine is a 1 followed by a 0 in the next block. What you're doing with
is assigning two values to the same variable, so he last one overrides the first. What you should do is set the value to 1 at the bottom of the script (assuming that you do this within a IF-test or something like that), and then at the top set the value to 0 - maybe with a check whether the value is 1 and needs to be updated.
A very general tip: If you can avoid reading parameters, do that, even if it means you have to create another variable of three. In most case you can save some CPU, while also getting a more readable script.
Hope this helps.
Hope this helps.
ok my script works now.
i added the setvalue(outputbutton,0) close at the begining
thank you for all your remarks, it helps me to understand further forward the button (and by the way the switch) concept
Vincent
Vincent
you mean reduce the input number ? i think about several technic to create variable of three but i am surebsork wrote:If you can avoid reading parameters, do that, even if it means you have to create another variable of three.
-use of multiple variable module
-multiply 2 button input value by 1 and 2 in order to distinguish their value at the script input
Hi Pansoul, sorry I was a bit unclear.
What I meant was: Avoid getting (and setting) parameter values more than once like in:
What I would have done, could look something like this:
Reducing the number of parameters isn't necessarily the best way of reducing CPU load - it's getting and setting the values (and of course the internal computations in the script) that eats the cycles. You can use different strategies; some are discussed in this topic: http://www.sensomusic.com/forums/viewtopic.php?id=1050, and there are also quite a few other threads where scripts and CPU are being discussed.
PS: Just noticed that once again I've made a bad typo. It should have been "...another variable or three". I guess a "variable of three" could be mistaken with the Multiple Variable module(?).
Code: Select all
IF ((GetValue(p1) = 1) OR (GetVaue(p2) = 1)) THEN BEGIN
IF (GetValue(p1) = 1) THEN BEGIN
IF (GetVaue(p2) = 1) THEN BEGIN
...Code: Select all
VAR b1, b2 : BOOLEAN;
b1 := (GetValue(p1) = 1);
b2 := (GetValue(p2) = 1);
IF (b1 OR b2) THEN BEGIN
IF (b1) THEN BEGIN
IF (b2) THEN BEGIN
