With this patch you can define a list of four different midi message who will be triggered/sent at the same time.
Credits to Bsork because it uses somes sub-patches from the "playlist" patch in the audio add-ons:
http://www.sensomusic.com/forums/viewtopic.php?id=922
Needs to be completed with data message...
In the midi add-ons section.
Multi midi message
whooa, a giant patch.
tkx for the addon.
always nice to see new midi tools
tried to understand what it does - and I failed.
maybe you could tell more about the intended usage? what does it do that would be hard to achieve otherwise?
tkx for the addon.
it works the same way as "playlist" by Bsork...
Each time you hit one of the "play" button, a set of four midi message are sent. You can choose for each one, what kind of message it is, his number, his value (fixed or a curve). The idea is to have a list of pre-configured midi message, wich can be sent with only one button. It can be useful for exemple to send four program change to external gear within a song...or to send four CC to a VSTi or external gear with curve "option". It's up to you.
For exemple, move the edit/current slider to 0, click on the "edit mode switch" and do your settings. Then click append (or update). Then move the "edit/current" slider to 1, do your settings...
When you're ok, deactivate the "edit mode" switch. Then you will be able to play your list backward or forward with
"<< Play" and "Play >>" buttons. It can be useful for exemple to send four program change to external gear within a song...
Bsork wrote "you can store sets of parameters within a single array, and add or truncate entries at the end, as well insert, update and delete entries from the array".
Hope it helps you.
Hope it helps you.
Seb.Dub
Users browsing this forum: No registered users and 4 guests
