What is the secret??
-e
[after three failed attempts to read the anti-spam code]
I SWEAR I know my letters and numbers..... they're not different in french, are they??
It is currently 28 Nov 2026, 07:52
Unread post by woodslanding » 27 Oct 2008, 07:46
Unread post by bsork » 27 Oct 2008, 09:00
Unread post by kara » 27 Oct 2008, 09:01
Unread post by kara » 27 Oct 2008, 13:23
bsork wrote:Hey, I won with 12 seconds!
Unread post by woodslanding » 28 Oct 2008, 07:01
Unread post by bsork » 28 Oct 2008, 08:25
woodslanding wrote:So the number value on the bus is irrelevant?? Is that the data they are sending??
Unread post by Stefan » 09 Nov 2008, 12:43
Unread post by Vincent » 09 Nov 2008, 15:20
+1!Stefan wrote:the GetBus-Module could have a combobox listing all the internal data busses for the interface builder
Unread post by Stefan » 09 Nov 2008, 17:26
Unread post by Vincent » 09 Nov 2008, 17:47
Maybe your pronounciation?woodslanding wrote:[after three failed attempts to read the anti-spam code]
Unread post by Stefan » 09 Nov 2008, 21:32
Unread post by Clearscreen » 10 Nov 2008, 00:48
Hi Stefan, you should replace the faders with 'audio output' modules that're found under 'input-output' in the modules section of the browser. this may also fix your second problem, but i'm not certain about that - see what happens and let us know i guessStefan wrote:The first thing is, I used a fader to provide a 'pin' for the outgoing audio-signal, because I obviously want to use this as a subpatch. I suppose this isn´t a good idea, but how can I provide a 'pin' in a different way?
Second problem: when I stop the playback of a source signal for a bus, there remains a constant value on the bus (=hanging note => *beeeeeep* ). I tried to fix this with 'pass only if changed', but I´m not sure, if this is ok for audio data?
And generally: I am trying to create my own routing with audioBusses. Basically I want to use 6-8 different VSTi´s and route them to several loopers and vst-effects. In the end I would like to mix all the signals together in some kind of 'master patch'. Is this totally weird (= can´t and shouldn´t be done) or do you think, that this could work?
Unread post by Stefan » 10 Nov 2008, 09:05
Unread post by bsork » 10 Nov 2008, 09:26
Unread post by Stefan » 10 Nov 2008, 14:17
Unread post by antwan » 10 Nov 2008, 14:51
Unread post by Clearscreen » 11 Nov 2008, 00:14
Return to “Patching questions”
