Mute patch
In the VST plugin window, there should be a random function to randomize all vst parameters at the same time. The best
would be a shortcut, for example ctrl+r.
And thanks to give as the free version almost fully functional!!!
By.
By.
@frank
yes it's a goo idea but more a 'deactivate' switch than a Mute?
@rv_coder
the problem is that in a vst only few parameters are interesting to randomize. For example in a synthedit vst a randomize all is unusable because most parameters are 'intern params'.
So for each parameter we should be able to set if they are randomizable or not and also set the random range.
It's very hard to implement...but not impossible...
@rv_coder
Hello Olivier,
I dont see what diference between a Mute buton and deactivate buton ?
Franck and friends
Franck and friends
mute concerns only the audio.
a patch can be active without sending audio (ie a change tempo track)
OK Olivier, I understand.
For me it is more interesting the "deactivate buton" because I want to mute the sequencer midi player too, not only wave palyer sequencer.
Franck and friends
Franck and friends
about the synthedit thing. did not understand? there are quite a few SE vst's with kewl randomizing features (when I was at that forum I think the trickiest part was to set the controls to the randomized value).senso wrote:So for each parameter we should be able to set if they are randomizable or not and also set the random range.
just for interest: why is it hard? many vst hosts have something similar (minihost, plogue bidule, orion, etc.)
however, not important
Users browsing this forum: Bing [Bot] and 58 guests
