midi .script file editor?
amiga909
Unread post by amiga909 » 20 Oct 2008, 18:53
found only this so far:
http://sdisle.com/smarthtmleditor/ // html editor, trial only
of course u could use an eclipse module or whatever...
but is there something free and small (only a .exe file) to develop midi scripts for usine?
among syntax colouring I'd like to have a source file folder browser, variables/methods/etc. inspector and basic text editing options (undo, find+replace, etc.)?
Unread post by senso » 20 Oct 2008, 19:24
yes you are right, the built-in script editor in Usine is basic.
Actually it's impossible to change it and use a third party editor.
It's not definitive but hard to implement.
the best free ware is NotePad++
amiga909
Unread post by amiga909 » 27 Oct 2008, 11:57
senso wrote:yes you are right, the built-in script editor in Usine is basic.
notepad++ is good indeed!thanks for the tip.
idea for the script module: a 'reload script' button would be great, saves much time if you want to work with an external editor?
Unread post by woodslanding » 28 Oct 2008, 06:55
Yeah, I've been using NotePad++ too. It's been really easy to get running with. I use the Pascal settings, and it seems to get the color coding right.
-e
Users browsing this forum: No registered users and 215 guests
