VST Parameter Control Combobox
Unread post by woodslanding » 15 Oct 2008, 06:30
I very much like the way Usine can automatically populate a combo box with presets from a VST--Brilliant!
But there is another similar kind of functionality I'd like to see Usine enable too. It would be nice to be able to automatically populate a combo box with the parameter names of a given VST, and use that to route controller input to the vst.
This would help the problem of VSTs with lots of parameters taking up so much space in the patchbay. If you just had an input called -parameter- (visible in the compact version of the vst) you could control-drag from it to create a special parameter combo box. Whatever control input you assign to the combo box would be routed to the selected parameter in the vst.
This is how my current setup works, and I love it, because I don't have to decide in advance which parameters I want to control in a vst. I can just select 'filter cutoff' from the combobox associated with a particular MIDI knob input, and start twiddling.
Of course, I can do this now in Usine the same way I did it in Reaktor, but I have to type in all the parameter values manually. And now I'm spoiled in Usine by not typing in preset names ;)
cheers!
-eric
Unread post by senso » 15 Oct 2008, 10:05
thanks, good & interesting suggestion.
It not an easy job to do that, but not impossible!
let me think about it.
goyya76
Unread post by goyya76 » 25 Oct 2008, 20:31
+1!
Actually, i was reading the forum and was ready to post a similar suggestion: if i link a knob to a VST parameter, it would be nice that the knob automatically gets the name of the parameter (so you don't have to type it manually.....) - maybe it's simpler than the combo box??
Ciao,
Goyya :)
Unread post by nay-seven » 25 Oct 2008, 20:46
goyya76 : try the fast creation mode : ctrl+shift pressed and drag a line anywhere from your parameter....
with only ctrl you have a slider...;-)
goyya76
Unread post by goyya76 » 25 Oct 2008, 21:07
@nay seven: trying in a few minutes.....i should have read the fu****g manual i guess!
thanks,
Goyya :)
EDIT: i tried it - fantastic! thanks a lot....i could not believe it was so simple!
goyya76
Unread post by goyya76 » 26 Oct 2008, 14:05
here we are again....the "fast creation" mode is really useful - i was wondering whether is possible to do something similar in the opposite way: suppose i have a sub-patch with 16 knobs, a way to auto-name them when i connect them to a pin....
If there's no way, it could become a suggestion!
Ciao,
Goyya :)
Unread post by senso » 27 Oct 2008, 08:55
Actually impossible.
let me think about this suggestions (not so easy to implement!)
goyya76
Unread post by goyya76 » 27 Oct 2008, 10:11
thanks for the attention! even auto-naming of a text field or label could work (don't know if it's easier than a knob)...
Ciao,
Goyya :)
Unread post by woodslanding » 03 Jan 2009, 08:44
Just wanted to bump this....
I have this working with MIDI input, but there is a limit of 128 elements this way, and I'd like access to all of them. I'm not sure I quite understand the difference between VST host control and MIDI control, so correct me if I am wrong. I just realized that I can control many more than 128 presets in a VSTi from within Usine, so I'm assuming this would also be true of parameters.
Also, you can have finer-grained control over parameters with direct data than with MIDI. Useful if I am sweeping a filter with a Usine LFO.....
I realize a combobox for parameters and a data input for values is a 'monophonic' solution, but I'm assuming if I could control the parameter input programmatically, I could send several streams of data "simultaneously" by pairing parameter number and value in a data array.
Of course, you could also implement this with a single array input, that expects parameter/data pairs.
cheers!
-e
Users browsing this forum: Bing [Bot] and 11 guests
