Usine multi core support
Clearscreen
Hi guys, i'm thinking about getting a new machine and wondering what usines multi core support is like. i'm jumping from an old dothan so anything will be an improvement but specifically i'm curious about the new quad core penryns - how does usine handle multi cores? i've seen the dual core switch in the setup buit obviously it makes no difference for me now - how well is usine optimised for this stuff and will the same optimisation work with the quad cores?
C.
C.
- senso
Multi core is very hard to implement for a modular environment like Usine. By definition you can't define the order of tasks to process, and this order can change if you change your routing in real time.
Usine is not like a normal DAW. In cubase every thing is fixed by advance.
So to resume, Usine use on core for audio and another for display.
Actually a quad core is not really necessary.
Kaspar
Maybe quad makes more sense, when Usine is used as a VST in a host, like Reaper for an example?
- senso
As a Vst , Usine optimization depends on the Host optimization.
If your host is multi-core Usine is so, and each instance of Uisne works as a separate thread.
Clearscreen
thanks for the replies - very nteresting stuff!! sounds like raw cpu speed might be better than quad core... unless i maybe host usine in ableton or reaper... what about vista 64 bit - does Usine run well with that?
Clearscreen
something else has occurred to me - what about with multiclient asio drivers - each instance of usine would then utilise separate cores wouldn't it?
- senso
yes probably (I'm not sure...)Clearscreen wrote:something else has occurred to me - what about with multiclient asio drivers - each instance of usine would then utilise separate cores wouldn't it?
Clearscreen
fair enough. how about vista 64 bit? does usine work ok with that?senso wrote:yes probably (I'm not sure...)Clearscreen wrote:something else has occurred to me - what about with multiclient asio drivers - each instance of usine would then utilise separate cores wouldn't it?
- senso
Normally works but in 32bits modefair enough. how about vista 64 bit? does usine work ok with that?
