problem with pad kontrol
héliouk 6
Unread post by héliouk 6 » 27 Aug 2008, 15:25
hi crazy usiner! !!
i begin to use a pad kontrol,with faders learned on pitch, and button with sounds.
the pad kontrol is linked to bcr 2000,and bcr to presonus, all in midi cable...
i've got 2 tracks controlled with this box,everything's ok,but, after a while everything is confused,the sounds are changing ,the faders can move together or play sounds instead of pitching...ouiaiouille!
i haven't tried to learn xy pad yet...
do you have an idea?? did someone got the same???
ethnix73
Unread post by ethnix73 » 27 Aug 2008, 18:42
Try to have a look at your cables (in usine), to see what messages are going through...
Seb.Dub
héliouk 6
Unread post by héliouk 6 » 27 Aug 2008, 19:47
messages seems to be ok ,no contradiction,but everything on the same midi channel,i'm gonna try to change the channel...
ethnix73
Unread post by ethnix73 » 27 Aug 2008, 20:38
Perhaps have you let your pitch fader and buttons on midi learn?
Seb.Dub
amiga909
Unread post by amiga909 » 28 Aug 2008, 10:22
yes, sounds your remote map is not set up correctly. maybe u did not see there is a little 'r' for each patch (right upper corner)? further there is the global remote setting.
why are you chaining your padkontrol and bcr anyway?
if your computer has 2 USB ports I would try to connect the devices separately.
with chained midi you might run into latency problems (certain messages like pitchbend can eat up midi bandwidth quickly, plus the midi optocoupler latency, plus the controllers software delay). on the other hand usine is still a bit confusing for using more than 1 controller device.
héliouk 6
Unread post by héliouk 6 » 04 Sep 2008, 10:23
thanks guys,no more problems using usb...
héliouk 6
Unread post by héliouk 6 » 09 Sep 2008, 18:03
in fact still problem,even with the pad on usb and bcr in firepod....even if i change the midi channel for each track....help!!!
héliouk 6
Unread post by héliouk 6 » 09 Sep 2008, 18:22
messages from the cable in usine are wrong, they're changing,more precisely when you play a sound on one pad,the same sound is played the first time you hit the other pad,and after it's changing,but still for a sound,never for silence(a note not assigned)...it doesn't seems to come from the pad,because messages are ok there....
strange...
ethnix73
Unread post by ethnix73 » 09 Sep 2008, 19:01
Could you tell us how everything is set up?
Send me a PM so that i can have a look to your patch if you want
Seb.Dub
Users browsing this forum: No registered users and 811 guests
