MIDI Looper
Kaspar
Unread post by Kaspar » 14 Aug 2008, 16:15
Hi again!
I said I was going to practice ;)
I want to build a MIDI looper in Usine. Something like the Multiplayer X5, but for MIDI.
What would be the best way to do it?
Here's my feeble attempt at it:
http://shup.com/Shup/56832/midi_looper_attempt.png
Half the patch is just me using trial and error.
Don't know how to sync it to the master tempo, so that when I'd press start it'd start to record and by pressing stop the loop length would be set.
All this using quantize.
Also, how to get that MIDI out later for recording it in a VST host?
Thanks...
Unread post by nay-seven » 14 Aug 2008, 16:21
hello
what about the piano roll module...?
you have synchro and quantize record options and you can export midifiles when you have finished.....
Kaspar
Unread post by Kaspar » 14 Aug 2008, 16:48
Didn't consider the pianoroll :)
Well, tried and back again...
I get an error: "Internal In Buffer Switch Time Info" if I insert the SeqMIDI module and press play.
http://shup.com/Shup/56841/pianoroll_error.png
How is it done right?
Unread post by nay-seven » 14 Aug 2008, 16:55
i was talking about the " piano roll " module
the seqmidi module is an old one , senso let it here for backward compatibility ...
Kaspar
Unread post by Kaspar » 14 Aug 2008, 18:15
Thanks, my mistake, that did it!
Now I wonder if I want to sync it to master, should I:
1) Insert MasterSync module
2) Connect it's cycle pos output to Piano Roll's sync input?
Unread post by nay-seven » 14 Aug 2008, 19:27
no , you don't need , there 's a sync for the play and one for the rec....
