Simple noob question: I've created tracks with CTRL+T, but I can't find the way to delete it!
How can I delete a track?
yep , no way for the moment
i've ask it yet too...
Hello Mgr La Tenaille,
If it's not an empty tracks, first delete the patches.
Just save your workspace, then quit and restart Usine with your workspace. You'll then have only non-empty tracks.
I know, it seems absurd.
But deleting tracks, what for, indeed?
When I see an empty track, I quickly find something to drop in it!
Just joking...
Just joking...
vincent michel
composer & novelist
composer & novelist
Vincent is right, but if it hasn't changed lately then it only works if it's the last (most right) track. I emailed Senso about this because I thought it was a bug, for reference I include his reply:
hello again,
thanks for feedbacks.
actually, only the last empty tracks are deleted automatically.
If you have an empty track in the middle of the worksapce you have to delete it manually by moving patches of the grid.
Seem to be strange but because of the total modularity of Usine it's not so easy to do that automatically (be sure to keep your routing).
Of course It's not definitive, one day I'll spend time to find a solution....
senso+++
hello again,
senso+++
La Tenaille
Fine, it works
...and I realise it's the same thing to delete empty patch grid lines.
Thanks for the tip
Fine, it works
Thanks for the tip
Users browsing this forum: Bing [Bot] and 34 guests
