I guess this is rather a noob question but here ya go:
I have about ten snapshots in my current workspace. I have created a keyboard split in Usine. With the lefthand I play always an organ vst and with the right hand various synth vsts on another track.
Now for ONLY one snapshot I want a distortion plugin (or whatever FX) for my organ. I insert the distortion plugin in the organ patch and a bypass button set to "off", rewrite the snapshot in conductor. Fine.
As the distortion FX should be inactive for the other snapshots I have to go through all of them and rewrite them with the bypass button set to "on" for the distortion plugin.
Is there an easier way without rewriting all other snapshots?
Using an FX only on one snapshot without rebuilding others
you can't really do it in an easier way in the actual version.
I plan to find something more friendly soon...
Sounds good, thanks.
Just to give you some more info on this:
I initially thought about a solution based on the current snapshot number like:
- if snapshot=x then disable bypass
- if snapshot unequal x then enable bypass
(please mind the language, I'm no programmer at all
The problem with this solution would be that I'm moving around the snapshots in the conductor a lot (up and down, so they get different numbers) depending on my current playlist.
So a solution like this wouldn't work very good for me.
Users browsing this forum: No registered users and 28 guests
