Hy every body,
is there a way to create an automatic mix with sequencer curves ?
For example :
There is 3 tracks. Each track play a list of sample in random mode with a stereo sampler module on each track.
Can i create 3 curves in the sequencer (One per track) and assign these curve at the three Mixer track volume ?
If yes, how can i do it ?
In fact, i want to create an automatic (and random) mix with a slow mouvement of the mixer track volume, during a long time. ( + 6 db on 5mn, for ex ....). Perhap's is there an easy way to do that ?
Thank you
Mix with sequencer
- nay-seven
what about a patch like this :
usercurve->( curve = user1 ) coeffToDb --->MixerOut( track=1 )
just click and drag this patch on first track of the sequencer..
- cmodica
Yes of course !!!
This patch is OK. Great !!
I tried something like that before but i put the 'usercurves' module, not in the sequencer patch, but in a track 1 grid patch, so the curve list was empty ....
Thank you,
it is exactely that i want to do.
Thank you,
- nay-seven
glad to help..
