some noob questions
kloz
Unread post by kloz » 13 Jul 2008, 04:05
i've been evaluating usine for a couple of weeks now...
..i have only scratch the surface of the program...seems awesome !!!
...i have 1 question...in the new version...the pianoroll (which i have used for the second time since previous versions...) seems to be unable to select multiple notes...and then drag them...(for example to drag a chord)...
...i am almost sure previous versions did this...but i didn't play with this module enough to be certain...
...i am talking about the free version...
...also..is there a way to rename a patch ?...i mean...when i open Usine for the first time the patches have their names (draw filter / bassliner / etc).
if i create one, i can select the color...but i can't change the name.
i can rename a track...and modules (like the pianoroll) by double clicking on it and sometimes right click....but i can't rename o just NAME a new patch.
maybe i must save it first in order to do that ?
those are my noob questions...i know this is stupid and i probably will come with more complex questions in the future (or more stupids...depends on the wheather)
i haven't had enough time to fully test this awesome program...maybe my future DAW for live performance....seems really cool...but i need time to investigate...
...PEACE
nofish
Unread post by nofish » 13 Jul 2008, 18:03
kloz wrote:...also..is there a way to rename a patch ?...i mean...when i open Usine for the first time the patches have their names (draw filter / bassliner / etc).
Like you said, "save patch as..." is the only solution I've also found so far.
If there's another way I would also like to know.
By the way, as I'm also still quite a noob to patching, I've found that "save patch as.." is always a good idea before fiddling around with patches, if something goes wrong you can simply reload the patch.
Unread post by cmodica » 13 Jul 2008, 18:04
You had to 'save as' your patch to name or rename it.
kloz
Unread post by kloz » 13 Jul 2008, 23:50
thanks !
...what about the Pianoroll ???
...i have deleted the old versions from my system so i can't test myself if it was able to select multiple notes.
maybe it was my imagination.
anyway...back to do more testing !
it's a wicked learning curve but i am enjoying it !
Unread post by senso » 14 Jul 2008, 10:44
You are right the piano roll is still in development. I try to improve it at each new release.
The multi-select is in my 'todo' list.
Be patient.
kloz
Unread post by kloz » 14 Jul 2008, 23:56
thanks senso...
...i just wanted to make sure
...seems i had an hallucination about previous versions working like this :p
...i'll be patient
...peace !
