Hi Senso, I love the new add ons, they're just what i've been looking for, and they mean i can now begin to properly start using usine live, HOWEVER, your synced bar recorder has a button on it called 'Play Input Sound'. Would it be easy to add this to the fixed bar recorder patch? At the moment, i have to mute my guitar track before i press record on the fixed bar recorder, otherwise the volume doubles while I'm recording the loop (obviously the audio is being routed to the patch while recording) and then goes back to normal when looping. Ideally i'd like the recorder to be silent while recording.
I look at these synced patches, with all their little maths modules and such, and i can;t make head nor tail of them. So any help wuold be greatly appreciated.
Thanks!!
Fixed bar recorder (sync) request
captaingoatboy
It already exist ! If not, you just have to open your eyes , let start your brain engine, and copy/paste these modules: play input ; ( = ) module , ( and ) module ; crossfader. Just link them as they are in you original sync bar recorder.
Not really complicated...
captaingoatboy
thanks, i think.
if i run into problems i take it i can ask questions without my eyes and brain being commented on?
it was cold, and it rained, and so i felt like an actor.
I wasn't blaming you. It was just an evidence for my superstar brain ! (joking) . Don't care about comments, just take care about the answer of your problem !
And sorry for my sarcastic humour...
Users browsing this forum: Bing [Bot] and 96 guests
