send Sysex
send Sysex
Post by cmodica » 08 Sep 2026, 20:46
I can’t seem to work out how to send a Sysex message like this:
F0 00 02 23 01 08 00 36 7F 15 01 F7
via Usine?
Thank you very much.
Post by oli_lab » 09 Sep 2026, 20:29
HI !
you'll have to convert your code in decimal and drop F0 and F7 :
becomes
0;2;35;1;8;0;54;127;21;1
you'll have to send a dummy code to have the data change at the sysex input to make sure that the code is sent.
Post by cmodica » 11 Sep 2026, 07:56
I hadn’t realised I needed to convert it to decimal.
All that’s left to do now is to patch a hexadecimal-to-decimal converter...
Post by oli_lab » 12 Sep 2026, 22:09
try to do a script,
otherwise, if there is only few data, you can use this very old piece of software to do the conversion : https://calc98.en.softonic.com/
Post by oli_lab » 13 Sep 2026, 00:18
made a usermodule !
Hope you're a PC guy, the MAC version will be available ina week or so.
Oli_Lab_commatextHEXtoArray.usr-win64
Post by cmodica » 13 Sep 2026, 12:30
Oh thank you very much.
Unfortunately i am a Mac user, and i’ll have to wait...` :roll:
I work with Usine since more than 20 years but i never learn script langage.
i know it's a shame... :oops:
